Guess the question is, why?, over other less expensive brands.
If you put in your trans, you will see an improvement in the way it shifts. I use their trans and diff lube in all my cars even my daily divers.
Engine oil is different. I only use in the Vette. It is pure synthetic using a polyol ester base stock. Red Line doesn't have a good, better, best oil, they only have best. They blend and package it all, nothing is out sourced.
I started using it about 10 years ago.
And what does it do better than other quality engine oils?
It is more consistent because of the base stock and does a better job at removing contaminates. I put a new diff in my car because I wanted a Quaife and 3:73 gears, and I put Red Line in it when I got the car new in 2006 and the shop that changed it out could not believe how good the inside of the diff looked because of the lube.
