Well it's not tragic, but I've always said there are no bonus points on a timeslip for style. I thought I had researched it well enough and had found the weight of the C4 9.5x17 A-mold wheels to be somewhere between 18 and 19#. So I bought a pair to replace the 19# C5 Z06 9.5x17 that I had been running for several years. Just before I had my new Hoosiers mounted today, I weighed them and they were 20#. So now I've added 2# total, just because I wanted to make the rear wheels match a little closer to the GTO skinnies on the front. Aarrrrrggg!
At least they look kinda nice.
I did find a little tidbit to help determine remaining tire life. A new Hoosier 275/40x17 weighs 21.5#. The same tire with cord showing weighs 17.5#. So once the tire wears down and the grooves fade away, I can weigh the tire/wheel and compare to the original 41.5#, knowing that 37.5# is the limit.
Yeah I've always known that the 17" A-molds were at least slightly heavier than the 17" C5 Z06 rims and even more so than the narrower C5 Y2k 'thin spokes'. Talking all factory/OEM of course, aftermarket versions of each of those almost always weigh more.
They DO look good though, I've always liked the style of the C4 era ZR1/Collector Edition/Grand Sport (and 4th gen Camaro SS) rims.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Originally Posted by jbsblownc5
Me too they provide a bit more of traction.
Tom we can always send Marc over when you race He is our weight management director. Makes me feel guilty about eating before I get in to drive and reminds me to remove everything that is not necessary
True.
Although I think Tom is on top of that already, he too knows what it takes to maximize a set up, a sort of 'southwest version of me' if you will.
I've been accused of taking an enema before racing and going commando to save weight. This extra 2# is just killing me, down to the point I'm starting to count calories. I'm ordering strawberry sundaes now instead of hot fudge, it's that serious.
Actually, I went to SIR (Tucson) yesterday to test out the Yank SS4000 and the only change for race prep was the new DR/wheels. Glovebox, console, and cubbies were full, so I'd estimate the car was ~200# over race weight. Even though the DA ranged from 4000 to 4600, it matched/bettered the previous PB for 60' times. Our Phoenix track opens next Friday for the first time since last March.
Tom you must be the west coast version of Marc
I would imagine to see some great numbers from you shortly, good luck
Btw I would think that by this time all of us would know how important weight reduction is.......(besides you & Marc)
Unfortunately the C7 has gained a few pounds but GM in its ultimate wisdom made it smaller on the inside so we all will have to lose a few pounds... end result no weight gain
