Needing Alternator Advice
Old Jan 19, 2014 | 02:42 PM
zo6style's Avatar
zo6style
Default Needing Alternator Advice
It is clear that the 06 C6Z has a deficient alternator and fails often at high rpm or intensive demand. I track my C6Z and need to replace my alternator with a HP type unit (prefer a bolt-on type).
Any recommendations? Please try to avoid providing anecdotal information. Links and experience with said product is appreciated.
Thank You.
Old Jan 19, 2014 | 02:56 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I went through 2 alternators before I found this one
http://forums.corvetteforum.com/c6-f...y-is-here.html
It fixed my problem completely. I got the 170A Chromed one.
Elmer
Old Jan 19, 2014 | 03:35 PM
zo6style's Avatar
zo6style
Elmer
Mr. Elder,
Thanks for the prompt and accurate information. I will contact their tech support Monday and discuss my needs as I think my unit will need a different size pulley to reduce the rpm of the unit.
Thank You sir.
Old Jan 19, 2014 | 06:34 PM
cclive's Avatar
cclive
I disagree with the basic premise of the question but I fully agree with Elmer's suggestion...quality piece.
Old Jan 19, 2014 | 07:54 PM
EVRose's Avatar
EVRose
I have that same alternator in brushed aluminum. Quality piece is right on.
Old Jan 20, 2014 | 03:16 PM
timd38's Avatar
timd38
They look so good I just bought one in black. The only issue with black, is that you need a ground wire.
Old Jan 20, 2014 | 03:26 PM
EVRose's Avatar
EVRose
Just grind off the anodized black where the alternator contacts the bracket and you won't need a ground strap.
Old Jan 20, 2014 | 03:28 PM
kedar's Avatar
kedar
St. Jude Donor '12
I also have the black anodized alternator, but did not use the ground strap. What I did is I sanded / filed away the anodizing from the back of the alternator where it makes contact with the metal bracket on the motor. This sufficiently grounds the alternator and obviates the need for the additional ground strap. Another user on the thread located in the forced induction sub-forum did the same thing, presumably with successful results.
Old Jan 20, 2014 | 05:56 PM
timd38's Avatar
timd38
Thank you!
Old Jan 21, 2014 | 10:37 AM
Unreal's Avatar
Unreal
I have the black 170A. It comes with the ground cable. All you have to do is take 60 seconds to undo the one ground on the block below the alternator, attach ground and be done with it. Was quicker/easier than sanding down the anodizing.
Old Jan 21, 2014 | 10:57 AM
timd38's Avatar
timd38
Thanks!
To Needing Alternator Advice
