C6 Bank 2 Sensor 2
Old Feb 7, 2014 | 08:49 AM
96BAM's Avatar
96BAM
Default C6 Bank 2 Sensor 2
Any trick to know about in removing the passenger side down stream sensor on a 2008 Corvette base coupe??????
Old Feb 7, 2014 | 03:23 PM
96BAM's Avatar
96BAM
Can any one tell if I need to remove the starter or cat??????
Ted
Old Feb 7, 2014 | 06:34 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Ted
Neither need to be removed
Old Feb 7, 2014 | 07:37 PM
96BAM's Avatar
96BAM
Is it easy to get to the electrical connection????
Ted
Old Feb 7, 2014 | 08:17 PM
erick_e's Avatar
erick_e
St. Jude Donor '13-'14-'15-'16
No need to remove the starter or cat.
I found the connector was the hardest part to disconnect.
Old Feb 7, 2014 | 08:21 PM
96BAM's Avatar
96BAM
Was under her the other day and that wire looked like it would a lot of fun. That's why I had asked on here. Guess I'll give it a try. Thanks for all the reply's.
Ted
To C6 Bank 2 Sensor 2
