Headlight gasket
Old Feb 8, 2014 | 01:23 PM
gsxr_rx-1's Avatar
gsxr_rx-1
Default Headlight gasket
What is the easiest way to remove the rubber around the headlight fastened with push nuts?
Old Feb 8, 2014 | 02:39 PM
RicK T's Avatar
RicK T
I haven't seen any posts directly addressing just the gasket.
In case they help, here are a couple that should tell you what you are dealing with and how to get there:
http://forums.corvetteforum.com/1565014752-post3.html
http://forums.corvetteforum.com/c6-t...placement.html
Old Feb 18, 2014 | 03:50 PM
RLSebring's Avatar
RLSebring
Supporting Vendor
From: Pensacola Florida GO GATORS!!! www.rlsebring.com www.c6c7vette.com
St. Jude Donor '17
Pretty much need to remove the headlight to access all the connection points of the gaskets.
To Headlight gasket
