Power Steering hose routing question
I removed the rack to replace the crank pulley - and the hose coming out of the bottom of the power steering fluid pump is giving me issues.
After sliding my steering rack out of the way - I got the hose router under the part that attaches to the steering column - and up and around into the top port.
I haven't torqued down the nuts to the cross member yet - but the top hose looks like it will line up and thread into the rack.
My problem is that the top hose is resting against the steering rack boot - and is prevent the rack from turning side to side....
Have I routed it correctly?
I took several pictures below - hopefully this helps show you what I am talking about.
take a break, drink a beer and get back to work.good luck.
i got about a half inch clearance now - the hose that pointed too with the red arrows below - i ended up routing the hose to the right of the fittings that you didn't have to take off when I pulled the rack.
The fittings look to be at the right angle - but I try to thread it in by hand and the things tighten a tiny bit then pop off - how hard should it be to get the fittings into the rack?
my fingers don't work like they used but after I threaded them in by hand, I used a line wrench to SNUG them up. I ran a drop of Teflon on the threads and checked the lines after running the engine and turning the steering.
