Here's the work I have lined up on my vette, I just wanted to see if you guys had any suggestions (within the scope of the modifications, and reason, of course!) for anything I might not have thought of that should/could be added on. The idea is to have a kickass daily driver, basically. Right now, she's scheduled to put down 670HP and 565lbs-ft torque to the wheels:
Edelbrock E-Force TVS2300
Ported LS3 cylinder heads
Competition Cams dual valve springs, titanium retainers, 10 degree locks
GT9 camshaft by Competition Cams
Larger fuel-injectors
Kenne Bell Boost-a-pump fuel pump voltage booster
160 thermostat
Dewitt Custom radiator/oil cooler
ATI Throttle Body Harmonic Dampener
Corsa Exhaust Crossover Pipe
Corsa Sport Pro Catback Exhaust
Ride Tech HQ Coil Over Suspension (track tuned)
LG G1 Swaybars (track tuned)
Corvette 427 Centennial Special Edition Rims
MGW Short Shifter
Black Onyx Tail Lights
Corvette Hatch Vent
Grand Sport Engraved Ball Shift ****
I've been looking at maybe installing hood louvres but I'm also wanting to keep the exterior relatively stock looking in terms of identifying any potential performance upgrades (rims and lights are common changes for all cars, even crappy ones haha). I intend to maintain 50 state legality, and in discussing some options with the guys over at Lingenfelter that are doing the install and what not, the general feeling for both of us was that headers are absolutely not necessary (and so they won't be considered).
Basically what I'm looking for are any cool of useful mod ideas that aren't outrageously expensive (bear in mind I'm already nearing $30k deep here haha). Interior mod ideas are cool too- I've already got some custom license plates made that read "1.21JW" and a prop-quality flux capacitor I'm going to hang in between the seats for good measure haha
Down South Vettes has great interior mods. I just a steering wheel and other good from them. Great quality products.
You know I considered a steering wheel. Do they have any that retain the airbag? I'd love a more performance oriented wheel but I'd also like to keep the airbag.
1.) No significant performance gain. Long and short of it. I had a discussion at length with the guys at Lingenfelter about why. Primarily it has to do with efficiency trade-offs between the super and the exhaust. In essence, the effect of adding headers produces an increase in exhaust efficiency that translates roughly equally to a loss in efficiency on the supercharger. Also, increasing the diameter of the tubes gives up low RPM performance for gains in high RPM performance- which is not beneficial for me, since I spend most of my time in the lower RPM band (below 6500). Ultimately the best performance decision for me is to maintain the stock headers for the GS while increasing exhaust efficiency via the X-pipe and Corsa cats.
2.) Headers make the car illegal in some states (looking at you, California), and I'm trying to maintain its street-legality in all 50 states.
Originally Posted by timd38
It keeps that air bag and the radio controls.
Awesome, I'll definitely check them out then and see what they have on offer. It looks like their site is down for the time being (being upgraded, apparently). So it'll have to wait!
I would suggest some tires...or an AWD kit. Otherwise, what's that power for?
I only have about 450 rwhp in my 1LT (11.5@124), and I don't see how I could even use any more HP on the street until past 100 (where I usually start thinking about my kids and let out). It's nasty and is on the brink of losing traction.
lol.. An AWD conversion is prohibitively expensive and would require SIGNIFICANT changes to the frame and drivetrain.
The tires are on the docket for when I burn out my current set (which should be soon after I get it back, since I'll be taking it to the track to tune the shocks and sway bar haha). I'm going to be rolling on Pilot Super Sports for everyday driving. May pick up a set of Sport Cups for track days..
Why the power? Why not? Because I want to, that's why I don't have kids to consider, and even if I did I probably wouldn't slow down. But mind you, I don't drive aggressively on the street (no need.. I know I'll win haha, and it's dangerous). It's for fun, and it's my dream car, so I'll be putting lots of power into it and enjoying every single horse. If you're content with 450 great! You don't have to mod it! I want more.
I assume you've had a car that powerful before. A good chunk of those horses will only help you go sideways and smoke the tires. I don't get the fun with that (part throttle until top of third gear); feels like the car is handicapped. But it's different strokes for different folks.
Yes, and no. No, a good chunk of the horses won't simply help you go sideways and smoke the tires. You're aware the ZR1 has nearly as much horses (638hp for the ZR1 vs. my 670ish), and more torque (604lbs-ft vs. my 565ish) than I do with this setup right (and torque is a more significant contributor to tire slippage)? As far as I'm aware, everyone drives with part throttle throughout..Well, all gears. It's called following the speed limit . As far as you mean in racing- certainly not. A properly tuned suspension setup along with the proper tires means you'll be getting the grip you want/need, and maintaining it through the turns (which you wouldn't be petal to the metal on anyways). With the tires warmed up, you can essentially drive ***** to the walls on the straightaways without concern for tire slippage, with the likely exception of some chirping on gear change which is hardly "smoking the tires". In any event, no one holds a petal to the metal to start- but you'll want some spin with the vette's wider tires anyways, a little spin then a bite into traction results in faster times than a cold launch without spin.
Yes, you can and will do both those things if you drive improperly though.
