Quick question about fuel filter
Old Feb 17, 2014 | 10:10 AM
Thomasmoto's Avatar
Thomasmoto
Default Quick question about fuel filter
I did a search to no avail, but is there a fuel filter on our C6's that should be replaced? Thanks.
Old Feb 17, 2014 | 10:35 AM
haljensen's Avatar
haljensen
The only fuel filter is part of the fuel pump inside the gas tank(s). Very expensive and time consuming to remove the tanks for access to the pump/filter.
Old Feb 17, 2014 | 08:23 PM
CMY SIX's Avatar
CMY SIX
a VERY fine stainless steel screen inside the fuel tank, fuel is pretty clean these days and it IS filtered before you put it in the car at the pump
Old Feb 19, 2014 | 11:02 AM
Thomasmoto's Avatar
Thomasmoto
OK well it was cleaned/checked when the blower was installed and the Z06 fuel pump was installed. So I should be good for some time. Thanks gang.
To Quick question about fuel filter
