Corvette wont start
Old Feb 18, 2014 | 01:04 PM
pamustiful's Avatar
pamustiful
1st Gear
Default Corvette wont start
I have a 2006 Corvette and wont start. The engine light come on and then it started changing from drive to reverse. I turned the engine off and tried to restart it but it wont start. The lights come on, the radio wont play and the horn works. So can you tell me what is possible wrong with it.
Old Feb 18, 2014 | 03:23 PM
EVRose's Avatar
EVRose
I would start with making sure your battery is fully charged. Have you tried jump starting it with another car? If that works then your battery is most likely bad.
Old Feb 18, 2014 | 03:48 PM
VET4LES's Avatar
VET4LES
Sure sounds like the battery.
Old Feb 18, 2014 | 06:28 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Is the battery the OEM original? If so, no doubt needs to be changed.
Old Feb 18, 2014 | 07:36 PM
truckplay's Avatar
truckplay
battery no doubt get a new one if it is more than 3-4 years old. Get a maintainer and plug it in whenever the car sits parked.
Old Feb 19, 2014 | 12:20 AM
cmorales515's Avatar
cmorales515
How many volts does your dash meter say you have when you try to start it?
Your problem could be a loose connection on the starter.
To Corvette wont start
