traction for 10GS with 7psi?
Old Feb 20, 2014 | 08:46 PM
prepass's Avatar
prepass
Default traction for 10GS with 7psi?
Can anyone give me recommendations for wheel and tire combo for traction from a stop for my 2010 gs with 7psi procharger tuned to 550 rwhp? Thanks in advance
Old Feb 21, 2014 | 03:28 AM
DillingerRadio's Avatar
DillingerRadio
St. Jude Donor '14
Stock wheels are fine, if you want to upgrade (change the look or whatever, I bought the GS sized 427 Centennial Edition satin black w/ red stripe rims for mine) go for it but unless you're on the track a lot you don't really need the meatier tire (and thus don't need a smaller rim).
Tires for street use, recommend the Michelin Pilot Super Sports.. For track use, give the Michelin Sport Cups a whirl. Bear in mind though- neither of these two options is cheap.
Old Feb 21, 2014 | 04:14 AM
meinersk's Avatar
meinersk
Mich wont hold your power.i have same power.without a burnout i dont know of any tire that will hold all of 1st gear....nitto nt05r 345/30/19 i have and they hold most of 1st gear and look mean. And they are 380 each not 500..mt et streets are good also..you need 0 treadwear to get best grip...make sure u stay wit in 1.11 inch diameter front and rear...
Old Feb 21, 2014 | 07:40 AM
prepass's Avatar
prepass
thanks meinersk. regarding mt et streets, they come radial or bias; which ones? are you a meineke guy?
Old Feb 22, 2014 | 07:00 PM
Danny Richie's Avatar
Danny Richie
I had the same problem. This is what I did: http://forums.corvetteforum.com/c6-t...and-tires.html
Old Feb 25, 2014 | 02:33 AM
meinersk's Avatar
meinersk
Wow a lot of trouble and money for u here ...My tires are for drag track .autocross and the street...I don't need to change them for either at my level ..rears are nitto nt05r 345/30/19 and fronts are 285/35/18 nt05 not r...I should have gotten 295/35/18...that size is alittle taller and would have looked better and size would have worked better .. But all I did was inflate front tires to 35lbs and rears to 32 to help in diameter difference. no I don't have anything to do with meineke
Old Feb 25, 2014 | 08:45 AM
Frans96ss's Avatar
Frans96ss
St. Jude Donor '09
MT makes a 19 inch tire now. They work great. I can get you setup with a set mounted and balanced if you want to stop by.
To traction for 10GS with 7psi?
