oil pressure high now?
Old Feb 21, 2014 | 01:49 AM
meinersk's Avatar
meinersk
Default oil pressure high now?
Oil pressure has changed...it used to not go over 60 at high rpm..now it will go over 75....also i was driving on the hwy and oil temp was at 118 to 124 degrees for an hour.it wouldnt go up...just changed oil 2 xs in the last week. ..used a mobil filter last change..i suspect something is wrong..
Old Feb 21, 2014 | 06:53 AM
Seadawg's Avatar
Seadawg
It is winter time, you know
Seriously, if you have a dry sump, it sounds normal for me in the winter, I see those lower temps all the time. It's been beaten around a lot on the forum too, search and you will see various posts by myself and others about it.
If you post your model year, type of engine (LS3, LS7, etc.), miles on the vehicle, if it is Z51, auto/manual, dry sump or wet sump, then we can tell you more "normal" parameters.
Old Feb 21, 2014 | 11:04 AM
meinersk's Avatar
meinersk
I searched forum and google.What has changed my oil pressure that is what im concerned with. Yesterday i had oil temps normal 150-180 and still oil pressure would go to 75.That would never happpen before.The oil smells maybe alittle like gas.
Old Feb 21, 2014 | 11:06 AM
meinersk's Avatar
meinersk
My sig is my car 06 z06
Old Feb 21, 2014 | 11:13 AM
C7/Z06 Man's Avatar
C7/Z06 Man
Install an OEM (AC Delco) oil filter (now).
Old Feb 21, 2014 | 01:20 PM
meinersk's Avatar
meinersk
Ya think thats it? I put mobil hi performance i got at advance...i picked up magnetic drain plugs. My 06 z06 did not have them.
Old Feb 21, 2014 | 01:54 PM
C7/Z06 Man's Avatar
C7/Z06 Man
Won't hurt.
Old Feb 21, 2014 | 08:49 PM
Cherokee Nation's Avatar
Cherokee Nation
Your oil temp is to low..Gey it to up around 210 & it should go down??
Old Feb 25, 2014 | 02:09 AM
meinersk's Avatar
meinersk
Yes its low but even when it 175 im still going to 75 psi ...it never did that before ...something has changed don't know what it is...but I want the pressure like it used to be 65psi max when warm.
Old Feb 25, 2014 | 02:38 AM
dlind4's Avatar
dlind4
Is it the same grade oil as what you had in it before? If its a higher grade that might be the problem as to why your pressure is higher.
Old Feb 25, 2014 | 07:15 AM
Seadawg's Avatar
Seadawg
keep us posted on what you find, this is an interesting one. Just a fyi though, my 2011 LS3 dry sump grand sport runs in the 70 -75 range when the oil is 150 degrees, when the rpms are higher than 2000.
When the oil is in the 100- 120 range, it will peg the needle (80 psi) and when I look at the DIC for oil pressure, it will be in the mid 80's.
Been that way for over 40k miles now.
Old Feb 25, 2014 | 11:06 AM
Cherokee Nation
My 08/LS3 will go up when i get it over 4000 rpm & my oil temp will be in the 180s..I think that is normal..Better then having LOW oil pressure..
Old Feb 25, 2014 | 07:58 PM
erikszr1's Avatar
erikszr1
nothing wrong with this car, stop looking for it to be broken. really.
Old Feb 26, 2014 | 01:59 AM
C7/Z06 Man's Avatar
C7/Z06 Man
Did you ever do the filter change?
Old Feb 26, 2014 | 11:19 PM
meinersk's Avatar
meinersk
Well I ordered ac delco filter it didn't come yet..oil is the same oil...Just changed plugs( full of sut) throttle body (full of oil) gear oil dirty trans clean 18,000 miles..getting a catch can...and to that guy if the car runs a certain way(max 65 psi) and then gos over 75psi something different and not for the better..I have no warranty..I blow the engine I have to buy a new one.This is the reason for concern..But thanks for your .02 if it was even worth that..Ill repost if filter solves issue
Old Feb 27, 2014 | 10:28 AM
Cherokee Nation
Why not change out to a new (Oil Pressure Sensor)??..The brand of filter is not your problem..I use the Mobil 1 filter,because at Advance Auto. has 5 qts & a Mobil 1 filter for $32.95.I've used the oem maybe twice & no change in the oil pressure
To oil pressure high now?
