Old Mar 5, 2015, 07:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
Print Wikipost
Shock Absorber Installation
Old Feb 22, 2014 | 06:42 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Default Shock Absorber Installation
This is for any DIYer out there that has replaced their shocks: Any tips or helpful hints for a DIY install? I'll probably being putting in a set of Bilstein HD's or Bilstein Sports on a Z51 suspension. Opinions on using the HD's or Sports welcome.
Old Feb 22, 2014 | 07:30 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Major tip I've seen on CF is using zip ties to hold the compressed shocks. As to Bilsteins, altho one recent poster w. base suspension is very happy w. Sports, the years-ago advice was that the HD is for base springs/sways, and the Sport for Z51. Obviously, it doesn't work for everyone.
I think I read that LG does a modified Bilstein to their specs. And, of course, so does DRM. I've heard they'll make it to any spec you want based on your use, your needs, etc. Might be worth a call to find out what they do and cost. Probably more tho than an off the shelf B8 HD or Sport.
Tell us what you wind up with!
Old Feb 22, 2014 | 08:58 PM
cclive's Avatar
cclive
Bill is right...something to hold the shock compressed is a major timesaver...zip tie, string, wire...whatever you have around. Put the two bolts loosely in the one end and then as you cut the tie, guide the single end into the hole.
Old Feb 23, 2014 | 03:13 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
That's pretty much what I gathered too from the Bilstein website. I'd like to see a post from someone who is running the Sports on a Z51 and see their feedback. Thanks for the tip on keeping them compressed.
Old Feb 23, 2014 | 04:02 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
unbolt the upper control arm from the frame, no need to wrestle with a shock to collapse it.
Old Feb 23, 2014 | 05:34 PM
Justasheet's Avatar
Justasheet
I tried the zip tie method. This method is WAY easier.
Jeff
Old Feb 23, 2014 | 05:41 PM
timd38's Avatar
timd38
Yup!
Old Feb 23, 2014 | 06:20 PM
cclive's Avatar
cclive
If you do decide to unbolt the control arm from the frame, which in my opinion is a very bad idea, be sure to replace the spacers exactly as they were, because alignment can be affected if things are not put back correctly. Replacing shocks is easy, to me there is no reason to unbolt major suspension pieces.
Old Feb 23, 2014 | 07:49 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
How do you collapse the shock and then zip tie it. Do you just compress it by hand or use a pry bar? and then zip tie from the upper mount to bottom mount? That's going to be a pretty long zip tie. A little clarity please. Also, on the rears doe the tie bar end have to be dropped from the lower suspension as called for in the shop manual?
Old Feb 23, 2014 | 08:30 PM
cclive's Avatar
cclive
Use your body and SLOWLY compress the shock against the floor. Remember what shocks do and you'll understand why you can't compress it FAST. I just used a loop of string, hooked it around when the shock was compressed.
Old Feb 23, 2014 | 08:55 PM
glenB's Avatar
glenB
Removing the upper control arm is no big deal and no worse than changing out a sway bar. With the ease of removIng the control arms, I'll have the car sitting back on it's wheels while you're still collapsing the shocks.
Old Feb 23, 2014 | 08:58 PM
timd38's Avatar
timd38
Same story here. I have done it both ways and removing the upper control arm is really easy. I have studs instead of bolts, so that makes it even easier.
Old Feb 24, 2014 | 08:40 AM
Justasheet's Avatar
Justasheet
I think his question was directed at shock removal rather than the install. I remember using bottle jacks, etc. It was a pia. I did one shock that way, including the install. I used ratchet straps to compress the shock to remove it from the car.
As soon as I decided to remove the a arm bolts, I was done in minutes.
I was due an alignment anyhow, which after being checked, was almost still spot on so I must have been careful.
Either way works but IMHO, the A arm method is way way easier.
Jeff
Old Feb 24, 2014 | 01:09 PM
jbomx363's Avatar
jbomx363
I'm in the "me too" for A Arm bolt removal. Easy peasy... and yes..make sure you put back the washers where they go. Some bolts have multiple washers too.
Forget zip tying.
I went with the DRM's because of the deal I got on them and have base springs, but Z06 sways. The sports IIRC are the ones to use with the Z51 option.
Old Feb 24, 2014 | 08:21 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
If you drop the upper A arm for the rears is there enough clearance to get the shock out without removing the tie rod end link?
Old Feb 24, 2014 | 08:40 PM
timd38's Avatar
timd38
Don't need to do that on the rears, just the fronts.
Old Feb 24, 2014 | 09:10 PM
Driver_WT's Avatar
Driver_WT
St. Jude Donor '07
That's what I did. Fronts only require unbolting upper control arm.
To Shock Absorber Installation
Old Feb 25, 2014 | 12:29 AM
vette6500's Avatar
vette6500
Me too.
Tried it both ways.
- Compressing zip tie/strap needed help from my brother.
+ Removing upper control arm was easy by myself, just watch the shims that may exist between arm & chassis, and put back unless you want extra negative camber.
Old Feb 25, 2014 | 12:24 PM
4SUMERZ's Avatar
4SUMERZ
I used the zip tie method to remove the old shocks, and install the new.
Old Feb 25, 2014 | 12:46 PM
glennhl's Avatar
glennhl
I had no luck with the zip ties, so I unbolted the upper control arm. VERY EASY!
