I am getting a random misfire on my 07 vette. Rough idle has gotten progressively worse. The following codes are displayed:
P0151
P0300
P1153
P0152
P0174
Upon reading up on this it could be an O2 censor, A bad battery, bad ground. It had Granatti plug wires but I put factory back on. Still getting same codes. ONLY modifications are... K&N Intake and Magnaflow Exhaust. Engine had 27,000 miles.
Never driven in rain, very clean. I checked for airflow leaks in intake, none found.
ANY thought before I pay Dealer hundreds for something that may be $50.00??
when did the light come on? Check to make sure that all clamps are on tight. Then clean the mass with special mass cleaner. Then check fuel pressure. Then make sure that the spark plug wires are tight. Sometimes they can wiggle loose and make sure the #1 wire is away from the alternator. Why did you change the wires at 27k ? Did you change plugs, did you use delco plugs? Could you have cracked one ? Did you replace the mufflers or the mid pipe also ? Could the harness for the 02 sensors be grounding out onto the exhaust ? Start working backwards since you first noticed the problem.
I bought the car from a Corvette enthusiast. He did the mods before I bought from him. The wires were changed in his words, because the new ones were 0 resistance and wanted to see if they made a difference. It didnt. He did keep the original factory wires which I put back on. I changed them back concerned it may be the issue. no change. I did chase the wires and connections. ALL look good and tight. No heat sources, worn wires or connection issues I can find. The car was running fine when I picked it up and ran fine for a month.
Mufflers were also changed. the problem started with a slight misfire. I thought maybe bad gas. All of a sudden it went to crap after about 30 days. On start-up its fine for about 1 minute at idle. it will start to run rough for about 10 seconds and the computer or something corrects it for about 45 seconds and it will do it again. vicious cycle or same idle issue.
My concerns are the vehicle didnt get driven much and an O2 censor is bad or something like that. All of the codes refer to bank 2 censor 1 if I am not mistaken.
Somethings definitely borked with the passenger O2. And with either of the O2's malfunctioning it throws the car into open loop full time which would explain the unburnt gas smell.
I will start with the O2 sensor. Everything is pointing that direction. Now I have to wait for it to be shipped.
