Which Wheels Will Fit
OK I have an 05 with the Z51 suspension, & my front wheels are OEM 5 spoke polished aluminum..
I bought a pair of 18" thin spoke off an 04 and have been using MT 305/35x18" with good success..
My problem is when I use those tires I was almost stock.. i.e. Headers, 2800 converter, FAST 102 thats about it..
I was 60 in 1.6x on average.. now that I have the new 403" I think I will also need 17" wheels...
Can someone help me I'd like "Thin 5 Spoke" (17") will the front 2004 fit on the rear of my 05 with the Z51 breaks..
The 18" I have on it fit perfect.. I'm looking for17" to match the front..
Is it possible .. I'll take OEM or Aftermarket..
They will fit. I ran fronts from a C5 with 275/17 MT for a while. They are 8.5 inches which work fine although C5Z fronts are wider and ideally better.
Thanks.. I'll get anything I can get...either OEM (preferred) or aftermarket... I'm running MT 18" now but have not had a chance to try them at a track.. Hopefully Fri will be ok as Cartek had a rental planned (weather permitting)
