You can R&R the intake manifold and R&R the oil pressure sender with hand tools in under 2 hours. No trick parts or procedures, just simple unbolt and remove; then rebolt to install. Torque wrench for the intake bolts is the only expensive tool.
Shop manual is a help but not required, most of the work is evident just from looking at it.
I agree! I replaced mine about 2 years ago and it was fairly easy to remove the manifold. Just make sure that you get an aftermarket sending unit. Several people in this forum told horror stories of replacing theirs with another stock GM sender, only to have it fail again after a short period of time.
I appreciate the reply's to my question. I do have the FSM and a good Torque wrench. Sounds pretty ease to do. I will buy a aftermarket brand.
If you have a 2005 Service Manual don't pay any attention to the part that says you have to drain the cooling system. There are no coolant passages thru the intake manifold. Somebody at Helms didn't do a fact check before they did the cut and paste.
