Need help choosing cam for 08 c6 ls3
Old Mar 19, 2014 | 06:32 PM
chase43's Avatar
chase43
Default Need help choosing cam for 08 c6 ls3
hello I need help choosing which cam i wanna go with for my 08 c6 ls3. All i am doing is headers and cam. I do not wanna do anything with heads or anything like that. Just a cam so I need help finding a good one for the LS3. Ive been looking at the lingenfelter gt12 and the katech torquer ls3. What other options do I have? I want somthin with a good lope to it.
Chase
Old Mar 19, 2014 | 07:49 PM
1987LC2's Avatar
1987LC2
Check out the April issue of GM HighTech Performance, they did a series of cam swaps on a Ls3.
The first one bigger than stock that they tested was a Brian Tooley Racing cam, 224/232° .624/.590" on 113°LSA.
It mirrored the stock dyno curve, just higher. No loss in torque anywhere. The 113° LSA should give you a little lope. The idle vacuum was the same as stock, as was the cranking compression. This indicates good street manners.
Peak power was up over 50hp, peak torque was up 23ftlb with no less than 20ftlb across the entire 3000-6500rpm power pull.
Check it out.
Old Mar 19, 2014 | 11:02 PM
BAKnBLK2010's Avatar
BAKnBLK2010
Is your car an A6 or manual? This will dictate what cam would be best....
Old Mar 19, 2014 | 11:47 PM
tuboy19's Avatar
tuboy19
If you're a manual car, the Spinmonster cam is great. It's even pretty boost friendly if you go that route down the line, ask me how I know...
Old Mar 19, 2014 | 11:49 PM
pnap88's Avatar
pnap88
I'm looking to do the same thing to my auto 2013 ls3!! can't decide as well
Old Mar 20, 2014 | 02:01 AM
AVB's Avatar
AVB
I just pulled a pretty mild PATG cam which got me just short of 490rwhp. Only thing other than stock for the LS3 was a set of LG headers.
If interested, I'll know in a week or two whether I keep it or sell.
Old Mar 20, 2014 | 06:47 AM
SK360's Avatar
SK360
Talk to PatrickG or Geoff@EPS.
Old Mar 21, 2014 | 01:17 AM
needcheese's Avatar
needcheese
LG6X3 is a nasty sounding cam. You need to be ready to have your valve springs changed around 15,000 miles or so with a big cam.
Old Mar 21, 2014 | 01:47 AM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
We have plenty of "book cams" and then we have custom grinds. Any individual will gain more from a custom grind as it is more fitted for what they are looking for, and we have them for $385. Cheaper than most off shelf cams. The best part of a street cam is the tq, and we believe in that. We can make them sound mean or tame and still pull like a freight train.
Give us a shout!
Old Mar 21, 2014 | 06:36 AM
dev1360's Avatar
dev1360
Contact PatG/Geoff@EPS or Brian Tooley. They have consistently shown themselves to be the best in the business.
I have a PatG/EPS 230/238 .629/.629 112+3
Overlap will generally determine idle and drivability. My cam has an overlap of 10* which is still street friendly with a good tune. The car pulls very good across the entire rev range. PatG/EPS have made a reputation out of having lobes that make good power while maintaining valve train stability and reliability.
45-145 pull:
Idle vid:
Old Mar 21, 2014 | 09:14 PM
COSPEED's Avatar
COSPEED
St. Jude Donor '10
There are even newer lobe designs out now that do even more. That is what we use.
Old Mar 22, 2014 | 02:15 AM
AllBlack_C6's Avatar
AllBlack_C6
Sorry to chime in on your thread but was curious to know how much and the name of the cam on the white c6
Old Mar 22, 2014 | 03:14 AM
dev1360's Avatar
dev1360
The car in my post? That's my car. Cam specs in my post.
Old Mar 22, 2014 | 07:32 AM
BOO666's Avatar
BOO666
Default Cam
There are plenty of grinds and even more opinions . Go custom . Call Geoff at eps . The cam will be garranteed to be ground within 1/2 degree of the numbers on cam card . Very simple process . I have a bolt on g/s . I made 517 rwhp with a mild cam through the pfadt cats . It sounds and performs as I asked for . When you order your cam it can be Taylored to your driving style , goals and your car .
Old Mar 22, 2014 | 08:46 AM
Archaic2021's Avatar
Archaic2021
Navigator
In on this thread!
I am doing a cam soon to my 08 ls3 also. I was gonna go with a "shelf" cam but my tuner talked me out of it. We're doing a custom grind cam and I'm eager to to see how it turns out. I'm shooting for 500rwhp with bolt ons and cam.
Old Mar 24, 2014 | 06:06 AM
SteveDoten@ARH's Avatar
SteveDoten@ARH
Premium Supporting Vendor
Brian Tooley. Call BTR.
While we are at it, how many LS cam grinders do we have ?
Comp
Cam Motion
Old Mar 24, 2014 | 06:34 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Comp
Cam Motion
Really? Who doesn't grind LS cams
Lunati
Isky
Bullet
Crower
Schneider
Howards
GM
just to name a few
Forgot Crane
And then there's the smaller custom shops
Based on experience, I wouldn't deal with EPS.
If someone is wanting an EPS type grind, Cam Motion, their grinder, has a profile that is very, very, similar to the EPS profile.
To Need help choosing cam for 08 c6 ls3
