Stripped Coolant Temperature Sensor
Old Mar 21, 2014 | 11:30 PM
ryccoh's Avatar
ryccoh
Default Stripped Coolant Temperature Sensor
I broke my coolant temp sensor didn't even take a lot of force.
I have the threads stuck in the head with the sensor part broken off.
There is a coolant plug on the passenger side head by the firewall, can I put another sensor there, the hole is larger though, or any other location?
I'm afraid if I try to get the old sensor out of the head that I will do more damage so since it's not leaking there I'd rather find a new spot.
What do you guys think?
Old Mar 22, 2014 | 05:49 PM
KENS80V's Avatar
KENS80V
The threaded holes on both heads are the same. The temperatures will read slightly different though.
