Katech 110 Torquer Camshaft (LS7)
Old Mar 24, 2014 | 09:50 PM
one bad Z06's Avatar
one bad Z06
Default Katech 110 Torquer Camshaft (LS7)
Hi, I have a 2006 C6 z06
current mods:
Volant intake
Magnaflow cat back exhaust
I'm looking to do a Katech 110 Torquer Cam on it. Anyone like this for a streetable cam? I don't want to ditch the cats , as of smog and I know I have my was around passing.
I drive the car almost daily if I'm not driving my duramax truck. I live in Los Angeles, so yes I know traffic sucks driving stick. I'm just curious if it's streetable with the extra power.
Pros and cons please
Thank in advance
Old Mar 25, 2014 | 07:25 PM
kenw's Avatar
kenw
VIR
You might want to do a search for information on this cam since it is very well liked on this forum. It is liked by many who run on a road courses because of the really nice torque curve of this cam.
From comments that I remember the cam is pretty large but is reasonably streetable. Although if your car is driven in traffic a lot you may want to go with a less aggressive cam.
Good luck.
Old Mar 26, 2014 | 09:32 AM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
I you haven't already....do a search and you should be able to get a lot of opinions.
Old Mar 26, 2014 | 09:48 AM
vertC6's Avatar
vertC6
Go to the Z06 section and read plenty of reviews
It has 12 degrees of overlap and the newer version has 4 degrees advance so it is VERY torquey, if you want a smoother cam for a DD go with the 116 LSA
Old Mar 31, 2014 | 05:06 PM
one bad Z06
good info thank you
Old May 3, 2014 | 05:27 PM
philpacs's Avatar
philpacs
The cam is drivable, but you will have to adjust your driving at lower rpm's some. At around 45 mph fifth gear used to be fine but now it will start to shudder unless under more than steady state throttle as an example. If not after that last few hp/torque for a track or ego then I'd go with a 116 which I heard drives almost stock.
To Katech 110 Torquer Camshaft (LS7)
