Steering rack hydraulic line removal question
Old Mar 26, 2014 | 02:20 PM
Petrolburner's Avatar
Petrolburner
Default Steering rack hydraulic line removal question
I'm in the middle of removing the steering rack so that I can swap my wobbly crank pulley. I've disconnected everything but the hydraulic lines. I'm not entirely sure which lines to disconnect and even less sure of how to get them to turn. They're a little rusty and there's almost zero access. I have the appropriate size flare nut wrench but I can't hardly get it in place much less turn it. I pulled the alternator so I could see what I'm doing but wow is that a rat's nest of hard lines. I've soaked the fittings in PB Blaster several times. Is it ok to use a torch on these fittings? Do I need crow's foot flare nut wrenches, 18mm? Anyone have a photo?
Old Mar 26, 2014 | 05:11 PM
Petrolburner
It looks like the one the magnet is on is the one to remove.
Old Mar 26, 2014 | 07:11 PM
tuboy19's Avatar
tuboy19
I normally just use a standard wrench 1/4 turn at a time until I can twist them by hand. It takes a while but I've made it work on several cars so far.
Old Mar 26, 2014 | 07:20 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Use the flare wrench if you can so you don't strip the fittings. The one on the top in your picture is the one I usually remove first then you'll have a bit more room to swing the wrench on the other one. Once they break free you can spin them with your fingers.
Old Mar 26, 2014 | 07:24 PM
3X2's Avatar
3X2
I use a 18mm 3/8 drive crowfoot socket, u-joint, and an extension to break the two lines loose. A stubby 18mm wrench to remove them from the rack.
Old Mar 26, 2014 | 08:57 PM
SPIN20's Avatar
SPIN20
Old Mar 27, 2014 | 01:39 AM
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
I use a flare nut wrench and have a little block that I set against the frame to gain leverage against the wrench with my 30" pry bar. Do not use heat on that to solve your problems or you'll end up with more to solve.
Old Mar 27, 2014 | 01:56 PM
Petrolburner
I was able to crack them loose with a regular open end 18mm wrench. Then, in painfully awkward positions I was able to loosen them the rest of the way with a pliers, 5 degrees at a time. Then the rest of the way by hand. What a PITA
Old Mar 27, 2014 | 04:14 PM
stroked383z28's Avatar
stroked383z28
If you unbolt the power steering pump and completely remove the alternator bracket from the motor it makes life a whole lot easier dealing with those lines.
Old Mar 27, 2014 | 04:21 PM
Petrolburner
I thought about doing that but got it out before I had to.
Old May 11, 2014 | 10:53 PM
Wayne walker's Avatar
Wayne walker
7th Gear
When removing steering rack I no the steering wheel have too be straight do I sucure the steering wheel with some type of restraint?
Old May 11, 2014 | 11:21 PM
07MontRedcp's Avatar
07MontRedcp
Originally Posted by Wayne walker
When removing steering rack I know the steering wheel have too be straight do I secure the steering wheel with some type of restraint?
You can use J 42640 (steering column lock pin) or an appropriately sized punch.
BJK
Old May 12, 2014 | 12:36 AM
Wayne walker
7th Gear
Do I leave the punch in in order too keep the steering wheel lock? I am doing a cam upgrade . Too remove harmonic balance bolt jam flywheel with some grips?
Old May 12, 2014 | 12:43 AM
Wayne walker
7th Gear
O7MontRedcp can u send me some pics or instructions on steering rack removal please?I have a 2008 c6
Old May 12, 2014 | 12:51 AM
Petrolburner
It's not going to move unless you get in the car, turn on the ignition, and move the wheel. The column isn't splined, you would have to turn it 180° to mess it up. Don't worry about it.
Old May 14, 2014 | 10:30 PM
Wayne walker
7th Gear
Default Cam installation
On the bottom of the condenser there is a hard line c6 corvette 2008 do I have too remove condenser too swap cam
Old May 14, 2014 | 11:14 PM
irok's Avatar
irok
Default J 42386-a
use factory J 42386-A flywheel holding tool by Kent-Moore
Old May 14, 2014 | 11:56 PM
Wayne walker
7th Gear
Default Thank you
Thank you
To Steering rack hydraulic line removal question
