Creaking Top
Old Mar 31, 2014 | 03:31 AM
96mogt's Avatar
96mogt
Ive tried a lot of the remedies. They help for a little bit but the creeking sound always comes back. I think living on an inclined driveway makes it that much worse for me. Ive honestly just learned to deal with the noise. Jay
Old Apr 1, 2014 | 12:37 PM
JCtx's Avatar
JCtx
Originally Posted by C6CentVette
I had to shim my trim so it wouldn't happen again.
My trim had a cut on top I filled with black silicone, but it's not touching the top. Probably a careless install at the factory or something.
Originally Posted by ErnieN85
Took the pins out and put in a Allen bolt through the header. The hole is already there
Do yo have pics of that? So you basically installed the top like Z06s? I like that . But besides pics, more specifics like bolt length and thread size. By the way, my pins are solid, but one front has 1 shim washer and the other 2. That's weird, no? And did you mean using those shims, or different ones? Would like to see pics to know what you're talking about. Don't want to remove the freaking roof again until I'm ready to do what you did. I'm trying to sell the car, so will wait to see what happens. Thanks for the help .
Old Apr 1, 2014 | 03:25 PM
ErnieN85's Avatar
ErnieN85
not much to take a picture of i layed the washers (maybe 3 each side) over the hole in the header just enough to let the roof line up with the header when the bolts were tight. with no washers the roof will bottom out on the header too far down past the top of the windshield. so its trial & error custom fit you can take the header pins to a hardware store
to get the right thread size i believe i used 1 1/4 inch length
Old Apr 15, 2014 | 09:34 PM
riverrat68's Avatar
riverrat68
Default roof panel noisey
Mine are hard to close. tried lubing. roof seams to make noise at the rear of the roof panal
Originally Posted by village idiot
are your levers (above visors) hard to close?
Old Apr 21, 2014 | 11:48 PM
dewilhite's Avatar
dewilhite
Originally Posted by JoeDoherty
I have a 2008 Base 3LT coupe. The problem I am having is a creaking sound from the top not a squeak. I have rubbed silicone grease all along the rubber seals but it has not helped. Any suggestions?
Joe:
Your 2008 may have the c-clip issue reported lots of other places. My 2012 top was horrible until I started using Super Lube on all the front latch parts. See the link below for my thread on this. It has solved a real problem on my Vette for several months now. Hopefully it will help you the same way.
http://forums.corvetteforum.com/c6-c...post1585933028
Old Apr 22, 2014 | 01:46 PM
Crawler's Avatar
Crawler
Something I haven't seen here as a potential fix has been the C7 roof pin bushings.
They are extra thick and conical.
I have swapped to these on my car and a number of friends. Of course all roof pins need to be checked for tightness (18lb/ft) and seals should be lubricated annually.
Depending on the condition of the latches some people can swap these on as is, others will need to trim them down slightly, as they are super thick.
Remove the factory o-ring from the C6 post and slide this in place.
My roof only creaks on hard bumps or with major chassis twist. Used to it would creak driving low speed over any imperfection. It's not the end all solution for everybody. But will fix a lot of the creak complaints.
Should cost 6-7 bucks at your local dealer.
Old Apr 23, 2014 | 04:43 PM
jedblanks's Avatar
jedblanks
Heatshrink tubing on the front and rear pins is the answer to the problem. Just slip it on and heat it until it shrinks around the metal pins, two on the front, two on the back. use the C-clip for extra insurance, but the heat shrink does the trick. I went through all the rest of the fixes on my new to me 2008 vette. Wish I had done the heat shrink first.
Edit: New orings are needed also. For clarity, here is a listing of the three items needed:
#31 O-Rings (10-Pack)
Model # 96745
Store SKU # 584164
3/8 in. Black Polyolefin Heat Shrink Tubing (3-Pack)
Model # HST-375B
Store SKU # 154106
3/16 in. Plain E-Clip (2-Pieces)
Model # 43638
Store SKU # 568622
Total cost was $5.14 at my local Home Depot.
Old Apr 23, 2014 | 09:25 PM
24/Eray's Avatar
24/Eray
i left nothing to chance.. Pulled transparent top due to "creak and pop" noticed the pins were only hand tight, fixed and lubed.. while i was there i tightened the "J" hook at the rear clamp up two turns (due to it not having "alot" of tension on it) and i also lubed the rear pins, weatherstrips and everything i could lol... Low and behold, fixed!! Thank GOD
Old Apr 26, 2014 | 06:21 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Bottom line is the handles at the front are squeeking and all you can do is unscrew them and lube the crap out of them with a high temp grease .The top gets hot and the grease melts out of the handles and causes the creaking all over again.grease usually good for a few mths.
Old Apr 26, 2014 | 11:36 AM
JoeDoherty's Avatar
JoeDoherty
Cruising
Thanks for all the replays. I used the o rings on the front pins and it cured most of the creaking.
Old Apr 26, 2014 | 02:35 PM
FactoryZ51's Avatar
FactoryZ51
when you get into the car, try simply unlatching and latching the top clamps. I've discovered that it creaks more when I leave it out in the hot sun. Usually it's quiet right after I do that. My guess is that the different plastics in the top expand causing the creaks. I think the unlatching helps relieve some of the pressure.
