power steering rack fitting leaking
Old Mar 29, 2014 | 11:02 PM
AK47's Avatar
AK47
Default power steering rack fitting leaking
I discovered that the power steering rack fitting is leaking, not a lot, but a noticeable amount.
What can caused that? I just had my crankshaft pulley replaced, and the rack was pulled, but those fitting were not touched.
How do I fix it? I tried tightening it more, but no results. Should I try using anti leak power steering fluid? Do i need to remove the whole fitting and put Teflon tape or sealant on it?
Thanks!
Old Mar 30, 2014 | 09:37 AM
filmjay's Avatar
filmjay
St. Jude Donor '10
It's been my experience that the steering rack does have to be removed to get the crank pulley off without dropping the cradle/lifting the engine. I had to when installing a UDP not 2 months ago.
Have you tried simply tightening the fitting? Or some RTV around the base may just take care of it, if it's tight already.
Old Mar 30, 2014 | 11:44 AM
MARSC6's Avatar
MARSC6
If its still leaking when tight it was probably damaged when the rack was removed. I would replace the fitting.
Old Mar 30, 2014 | 02:45 PM
Dano523's Avatar
Dano523
Take the car back to where you have the HB replaced, and let them deal with the leak.
Chances there is debris on the mating surfaces of the seal, and the problem at hand instead of just a loose fitting.
Old Mar 30, 2014 | 10:18 PM
383's Avatar
383
RTV wont work if its leaking. Ask me how I know. Cut your losses and pull it out, that is if the shop that boogered it up wont fix it.
Old Mar 30, 2014 | 10:39 PM
AK47's Avatar
AK47
i did take it to that shop, but their story is that they never touched that fitting while changing the HB, so it couldn't of been them etc...
Old Mar 30, 2014 | 10:45 PM
AK47's Avatar
AK47
well it wasn't leaking before the HB swap, so most likely something got screwed up.
is it possible to swap the fitting without pulling the whole steering rack? but then I am not sure which part is damaged, the mail or the female..
Old Mar 31, 2014 | 07:53 AM
MARSC6's Avatar
MARSC6
Disconnect the line and check it out. I'm guessing they bumped the fitting on something when they were moving the rack around. Its possible to only be dirt but I've never been that lucky with a leaky Hy. fitting.
Do not use teflon tape. I've had to pick it out of a valve once after another mechanic tried to to be lazy.
To power steering rack fitting leaking
