Strange Question
Old Apr 1, 2014 | 05:21 PM
Jim Bell's Avatar
Jim Bell
Default Strange Question
Is it normal to have more exhaust coming out of the right side than the left side of exhaust pipes? My C6 has always been this way. It seems to effect nothing.
Old Apr 1, 2014 | 10:03 PM
Jim Bell's Avatar
Jim Bell
Any help. Thank you.
Old Apr 1, 2014 | 11:47 PM
owc6's Avatar
owc6
Are they stock pipes?
I have Bullets, and more carbon builds up in the center two. The outside two have, maybe, 1/2 the carbon.
lisa
Old Apr 2, 2014 | 06:17 AM
Jim Bell's Avatar
Jim Bell
They are Cherry Bomb Axle Back made for the C6. I have more on the right side and 1/2 or less on the left side.
Old Apr 2, 2014 | 10:31 AM
haljensen's Avatar
haljensen
You might have failed packing/insulation or a broken baffle in the muffler on the left side.
Don't know how you could check it. Maybe disconnect both mufflers at the mid pipe and see if the pipes flow equally before the mufflers?
Old Apr 2, 2014 | 12:59 PM
corvetteflier's Avatar
corvetteflier
lisa
Same with mine. But they are all equal, as you would expect, as Bullets have nothing to clog up with as there are no mufflers of any type. Having more on one side would indicate something blocking flow.
Old Apr 2, 2014 | 02:58 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Are you saying more exhaust as in pressure at the pipe or more exhaust as in one side discolors before the other?
Old Apr 2, 2014 | 03:32 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
It is not unusual on a Harley Davidson touring bike at all. Even though they have "duals" most of the exhaust comes out the right due to the design of the crossover pipe.
On a Corvette, you have four tailpipes. If you have the NPP option (or you have a Z06 or ZR1), your outer tailpipes are used for 100% of the exhaust - until you exceed 4000 rpm at WOT (I might have the parameters slightly off) then the inner pipes will open via a vacuum operated butterfly. The butterflies close when you let off the gas and you're back to the outer tips. You will note substantially increased sound when this happens. If you like this increased sound you can buy devices to give you this control at will.
If you are referring instead that your right muffler has more exhaust output than your left muffler, that is indeed unusual and would be indicative of a problem (clogged catalytic converter, internally broken muffler, are two examples). Often when there is such a problem you will hear a "jet like" sound from the clogged side.
But before I jumped to too many conclusions, how are you measuring it? With your hand? That's probably not accurate enough to get a good measurement I'd say - but if you had a small weather vane you could put it in the flow and read the rpm, I guess.
Old Apr 3, 2014 | 05:52 AM
Jim Bell's Avatar
Jim Bell
One side gets blacker than the other. The right side has always more carbon build up.
It did this with the stock mufflers as well. I just recently in the last two weeks put on ARH's and have had the Cherry Bomb System for a while. Same thing. More black on the right than the left.
Old Apr 3, 2014 | 08:02 PM
ruxvette's Avatar
ruxvette
My guess is too much fuel (injectors) or bad spark (ignition). Either way, it is time for a reputable shop to take a look.
Just sayin...
Old Apr 4, 2014 | 12:29 PM
JCtx's Avatar
JCtx
With an X-pipe like our cars have, you're never going to know which side of the engine is causing it just by looking at tip carbon build-up. But unless excessive, it's normal. Remember when you first start the engine when cold it has to run extra rich, and that contributes for most of the soot.
Old Apr 4, 2014 | 12:36 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
And at WOT a factory tune has around 11.1 AFR so that's really depositing a lot of soot. After track events even with my cutouts my pipes are BLACK.
To Strange Question
