Need Help Failed Inspection today 2005 coup
Old Apr 1, 2014 | 07:40 PM
REODAWG's Avatar
REODAWG
Default Need Help Failed Inspection today 2005 coup
Need Help Failed Inspection today-engine light on guy at the shop said he cleared the engine light but came on again he know says I need a sensor that's in my gas pedal anyone know where its located and where to get one and can I do it my self
I looked at gas pedal but see no sensor
Old Apr 1, 2014 | 08:10 PM
RicK T's Avatar
RicK T
Did he tell you, do you know, what the specific code is?
The C6 being a drive by wire, aka there is no mechanical connection between the gas pedal and throttle blade, it's done by the computer. The accelerator pedal is basically a rheostat. What's in it is the Accelerator Pedal Position Sensor.
Usually when it goes bad the car can't be driven. That's why I ask if you know the exact code.
Old Apr 1, 2014 | 08:37 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Not sure if '05 and '08 are the same but when my (one of two) sensors went out in the gas pedal assembly, my car went into limp mode---from 65 to about 45, missing, service messages, reduced speed message. Dealer said pedal has two sensors on mine, better to replace whole/both. They did. If you didn't have those symptoms I'm a bit surprised.
Old Apr 1, 2014 | 08:38 PM
REODAWG's Avatar
REODAWG
no he did not give me the code but I will ask him tomorrow he said it was that or some other sensor that has to do with the pedal do you know what that would be
Old Apr 1, 2014 | 08:40 PM
REODAWG's Avatar
REODAWG
no none of those issue just a check engine light
Old Apr 1, 2014 | 08:43 PM
REODAWG's Avatar
REODAWG
do you know what the second sensor was other then the pedal
Old Apr 1, 2014 | 08:49 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
No, I don't; sorry. But it is all in the gas pedal and the tech said, if one goes, who knows when the other might, too. Maybe that's the easy way out, but it did kind of make sense at the time.
Old Apr 1, 2014 | 09:04 PM
BluV's Avatar
BluV
St. Jude Donor '09-'10
If he cannot give you the error code, then go up to your local parts store (o'rielly, napa, autozone, etc). Have them hook up the scanner and get the codes. Then come back here and post up the codes for us...we can figure it out from there.
Old Apr 1, 2014 | 09:23 PM
saplumr's Avatar
saplumr
I've never heard of failed inspection due to CEL. Is it one of your state laws instrumental panel is checked?
Old Apr 1, 2014 | 09:31 PM
Jimmy C-6's Avatar
Jimmy C-6
St. Jude Donor '12-'13
The poor guy lives in Mass. that's what threw the code. LOL No inspection in Michigan.
Old Apr 1, 2014 | 09:52 PM
BluV's Avatar
BluV
In TX, if the check engine light is illuminated, they won't even start the inspection process - automatic fail. Which is hilarious since they never check to see which CEL errors have been completely disabled....
Old Apr 1, 2014 | 09:57 PM
saplumr's Avatar
saplumr
Not to sound silly but what is the reasoning for checking the instrument cluster other than mileage?
Old Apr 1, 2014 | 10:52 PM
MARSC6's Avatar
MARSC6
That plus checking gas cap is the emissions test for some counties in PA.
Old Apr 1, 2014 | 10:57 PM
BluV's Avatar
BluV
Sorry - I have no insight into why politicians do what they do. I always assumed they think they are being smart in that the CEL will alert a technician to smog equipment issues....but in reality they are pretty stupid to not know that I can disable just about anything thru the tune.
Maybe they are just keeping the honest...honest ( or so the saying goes).
Old Apr 2, 2014 | 07:45 AM
MARSC6's Avatar
MARSC6
All the tested also have to be completed. If you clear a code you have to drive enough for the test to complete and pass.
Old Apr 2, 2014 | 07:59 AM
timd38's Avatar
timd38
That is how it is in Milwaukee. You have a light, you don't pass. You can have the cats off, put out all kinds of nasty stuff, but if the light doesn't come on, you pass.
Old Apr 2, 2014 | 12:14 PM
irok's Avatar
irok
there is a sensor on your throttle pedal assembly. the other is on your throttle body.I just purchased a new throttle pedal assembly for a spare.new OEM are available for $44. if you look for one.gas pedal assembly with bracket and sensor p/n 25835421. if you can remove 2 bolts and unplug 6 pin connector you should be able to do it yourself
To Need Help Failed Inspection today 2005 coup
Old Apr 2, 2014 | 03:03 PM
REODAWG's Avatar
REODAWG
irok do you know the part number for the throttle body sensor
Old Apr 2, 2014 | 03:15 PM
irok's Avatar
irok
Default built in
its in the throttle body and is not serviceable.we need the code that cel set to have a better idea.dont really think its your throttle pedal sensor
Old Apr 2, 2014 | 06:47 PM
REODAWG's Avatar
REODAWG
got the code today it says PO121 THROTTLE POSITION SENSOR 1ant one know what that is
