Tr 6060
Old Apr 2, 2014 | 11:31 PM
meanjoe's Avatar
meanjoe
Default Tr 6060
Any idea if the newer TR6060 transmission is really any better than the 05, 06, 07 version? I have the 07 and can't find any problems with it. Opinions please.......
Old Apr 3, 2014 | 04:30 AM
dev1360's Avatar
dev1360
05 to 07 had a T56. The TR6060 had wider gears, thinner synchronizer assemblies, tighter clearances, and a host of other changes I can't think of off the top of my head.
The 6060 had a rated torque capacity of 700WTQ IIRC. It is an improvement by a pretty large margin, but the T56 isn't junk.
Old Apr 3, 2014 | 05:42 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
15% wider gears made of stronger material (4615 alloy), they removed the slider keys that caused catastrophic failures over a 10 dollar part. With the key-less design, the engagement is much smoother. The synchronizer teeth are much smaller, but there are many more of them. If you miss a gear, it's easier to chew up the teeth, but more difficult to miss a gear to cause the problem in the first place.
Under hard acceleration, the fluid is pushed to the back of the case, starving the gears of cooling and lubrication. The TR6060's have pumps that pump to a cooler and the return is to the counter shaft, which is the critical part in need. In 2010, they moved the pickup further back so the pump wouldn't cavitate so easily and the return was moved to a more optimum place on the counter shaft.
The T56 is not junk, especially with the 30 spline shaft in it, but the TR6060 is far superior IMO.
I began with a stock 6060 from an 08Z in my C5 and beat the crap out of it for 2 years with over 1kRWHP and never had an issue with it.
If you're making 600RWHP, do you need a 6060? No, but I think you'll appreciate the smoother shifting and believe that it'll last through more abuse.
Old Apr 3, 2014 | 08:41 AM
meanjoe's Avatar
meanjoe
Thanks for the info. Any idea what a T56 will bring for sale? 10K miles.
Old Apr 3, 2014 | 09:09 AM
Walt White Coupe's Avatar
Walt White Coupe
Having owned both, I can tell you that the new trans (TR6060) shifts a lot smoother than the earlier (T56) transmission..
Old Apr 3, 2014 | 01:47 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
I couldn't have said it better myself.
We take trades on low mileage T56 for a built TR6060. Call us for details.
I agree.
__________________
Old Apr 3, 2014 | 01:50 PM
timd38's Avatar
timd38
So does any one know what a new TUET 6613 Trans cost new?
Thanks!
Old Apr 3, 2014 | 01:56 PM
Supporting Vendor
Thanks!
$3,800 new retail. $3,400 if you can find a good deal.
Old Apr 3, 2014 | 02:00 PM
timd38's Avatar
timd38
Do you sell rebuilts with no core?
Old Apr 3, 2014 | 02:21 PM
Supporting Vendor
Yes but only fully built. Call us for a quote.
To Tr 6060
