License Plate Bulbs
Old Apr 3, 2014 | 07:40 AM
Jim Bell's Avatar
Jim Bell
Default License Plate Bulbs
How do you change the license plate bulbs? Have a 2006 C6 and need to change bulbs on license plate. Thanks.
Old Apr 3, 2014 | 12:31 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
If I remember correctly. remove one of the inboard taillights
then remove screw holding licsence light to rear fascia.
Reach thru the taillight hole and relamp
Old Apr 3, 2014 | 01:12 PM
JCtx's Avatar
JCtx
No need to remove any taillamps, but it's easier that way. Since I had the cables maxed out on my EE taillights, I did it without removal. Either way, it's easy as pie. You might want to put LEDs now. Good luck.
Old Apr 3, 2014 | 02:10 PM
Jim Bell's Avatar
Jim Bell
I did purchase LED's. It looks to be 2 screws per housing is that right?
Thanks.
Old Apr 3, 2014 | 08:15 PM
miklemke's Avatar
miklemke
Yes, just remove the two screws and work the entire assembly out of the facia. If you're doing LED's try them before screwing the assembly back in. LED's are polarized, so they must be properly oriented in the socket or they won't work. If they don't work, just turn 180 degrees.
Old Apr 3, 2014 | 09:51 PM
Anthony0224's Avatar
Anthony0224
Coincidentally, I just put in new red led license plate bulbs on my 08 c6 about an hour ago. It only took me about 5 minutes, but I did it the tail light way. Looks awesome! I would post a pic but the camera makes all of the lights look white...
Old Apr 4, 2014 | 10:54 AM
Jim Bell's Avatar
Jim Bell
Thanks for all the help guys.
Next questions: How do you change the reverse light bulbs?
Old Apr 4, 2014 | 09:29 PM
Anthony0224
http://forums.corvetteforum.com/c6-c...se-lights.html
To License Plate Bulbs
