Doing a engine swap on a 2010 GS. Those of you that have dropped the engine out from the bottom, where did you wind up removing the brake lines.....top of the ABS controller?
2020 Corvette of the Year Finalist (track prepared)
2019 C6 of Year Winner (track prepared)
Originally Posted by gnfan
Hello everyone!
All you need to do is disconnect the two bolts holding the ABS bracket to the front subframe. Nothing else that's brake related needs to be disconnected.
Maybe I missed something, but I don't see how you can not remove the brake lines one way or another dropping it out the bottom.
