Convertible trunk panel
Old Apr 11, 2014 | 01:17 AM
1@Orangevette's Avatar
1@Orangevette
Default Convertible trunk panel
I was wondering if anyone knows how to disconnect the sensors for the trunk panel and that the top will still work with the panel removed? I am having problems with the panel, if it get's bumped a little the top won't work. Thanks, Russ
Old Apr 11, 2014 | 08:57 AM
icntdrv55's Avatar
icntdrv55
Seems as if an easy fix would be to simply bypass the safety switch and hard wire the circuit. Then don't forget to check your trunk for bulky items every time you want to go topless!!!
Old Apr 11, 2014 | 11:35 AM
1@Orangevette
Thanks for your reply. I am going to take your suggestion and look to see if there is a way to bypass the sensors. If there are just plugins behind the pegs that hold the panel on I should be able to jumper wire them I hope. Yes I know about watching not to get anything under the top when down. I had a C5 before that didn't have the panel. Thanks again.
Old Apr 11, 2014 | 12:27 PM
RicK T's Avatar
RicK T
Or just tape over the switches to hold them down.
Old Apr 11, 2014 | 12:41 PM
1@Orangevette
Default Trunk panel
Thanks for the suggestion, I'll see what it looks like if taping wound work or not.
To Convertible trunk panel
