Drag Radial Question
Old Apr 11, 2014 | 09:16 PM
silversvo's Avatar
silversvo
Default Drag Radial Question
I have been told I can run a C5Z06 rear 18X10.5 wheel with a 315/30/18 drag radial and it will fit under a Rear widebody fender okay. Before I bite the bullet and buy tires, I want to make sure they look okay. Does anyone run this size and if so, can you post a pic please? It is just for the track and not normal street usage.
Thank you,
Old Apr 12, 2014 | 05:56 PM
old motorhead's Avatar
old motorhead
Thank you,
That tire is almost an inch and a half shorter than your stock rear tires. If you don't run a shorter front tire, it's going to drive your traction control nannies completely batsh!t crazy.
Old Apr 12, 2014 | 08:46 PM
HOXXOH's Avatar
HOXXOH
Unless you have 550+ rwhp that tire is not your best choice. Try 275/40x17 on C5Z06 fronts or any other 9.5 x17 wheel.
To Drag Radial Question
