battery?
Old Apr 11, 2014 | 10:23 PM
hig4s's Avatar
hig4s
Default battery?
After sitting and listening to the radio for about 20 minutes it wouldn't start. I have a 2011 DD with 48k miles. Is it time to replace the battery or does sitting in aux drain the battery that fast. Since getting it jumped it seems to be fine the last two days.
Tried to do a search but something about the sites drop downs wouldn't allow me to sear h from my tablet
Old Apr 11, 2014 | 10:32 PM
saplumr's Avatar
saplumr
I can listen to the radio in my wifes Acadia for an hour at a time while she's in a store and never skip a beat. Turn the acc on and off, times out in 10 mins then back on/off for the next 10. Could be your battery is getting weak.
RicK T's Avatar
RicK T
Well, 3 years/48k shouldn't necessarily mean a new battery but we know it's a strong possibility/probability. IMO, since you rely on the car as a DD it would probably be prudent to put a new battery in it.
Old Apr 12, 2014 | 09:43 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Seems to be wise to replace Corvette batteries if you have any issues with them. I have killed batteries by sitting in my truck listening to the radio at lunchtime.
This fixed that problem.
Old Apr 12, 2014 | 06:33 PM
VET4LES's Avatar
VET4LES
I listen to my radio every day at lunch for 30 minuets and it starts just fine four hours later. It sounds like you need a new battery.
Old Apr 12, 2014 | 07:54 PM
Cherokee Nation's Avatar
Cherokee Nation
That is normal on my 08,even with a almost new battery??
Old Apr 13, 2014 | 02:00 PM
ant21b's Avatar
ant21b
Check the current drain on the battery with the engine off and with the ignition off. A small ammeter is required put it in series with the battery by disconnecting the negative terminal from the battery. Negative battery post goes to negative connection on ammeter positive connection on ammeter goes to negative wiring terminal. If its too high you need to find out why ( not in reverse for manual, interior lights on or something else). Ammeter should be on 10 amp scale to start. Also fully charge the battery with a battery charger with the negative post still disconnected and then load test the battery with the negative post still disconnected. You might also have to check the current draw of the radio I believe the fuse should blow though if its too high. One last thing is the alternator charging the battery correctly and how much current is the starter motor drawing when starting and are all the connections clean and tight on the alternator and starter. Sorry but any of these things could be it so it requires some investigation. Probably not the starter though check it last.
To battery?
