New intake installed, car won't start
Old Apr 14, 2014 | 01:33 PM
C6Goyo's Avatar
C6Goyo
Default New intake installed, car won't start
Last night I installed a new intake and now my car won't start until I pull the battery. Any idea whats causing the issue? It wasnt like this before. Its an 05 Z51. Any help is greatly appreciated
Old Apr 14, 2014 | 01:53 PM
turboffr's Avatar
turboffr
St. Jude Donor '10
Cold air intake or intake manifold? Is MAF plugged in?
Old Apr 14, 2014 | 02:33 PM
C6Goyo's Avatar
C6Goyo
Cold air intake and yes maf is installed
Old Apr 14, 2014 | 03:13 PM
tennblkc6's Avatar
tennblkc6
i'm confused. you state that it won't start until you "pull" the battery? what exactly are you doing when you pull the battery and it starts?
Old Apr 14, 2014 | 04:59 PM
C6Goyo's Avatar
C6Goyo
The car won't start after sitting for a little. When I unplug the battery it resets everything and it'll start. I'm confused as well.
Old Apr 14, 2014 | 06:05 PM
haljensen's Avatar
haljensen
How do you "unplug" a battery?
Old Apr 14, 2014 | 06:37 PM
C6Goyo's Avatar
C6Goyo
You remove the power cable from it... Disconnect it
Old Apr 14, 2014 | 06:55 PM
haljensen's Avatar
haljensen
So, if you disconnect the negative cable then reconnect it everything works?
If so I suspect you have a bad cable connection, probably at the battery but could be either end of whichever cable you are disconnecting..
Old Apr 14, 2014 | 09:24 PM
tennblkc6's Avatar
tennblkc6
yeah...sounds like a relay may be sticking. may want to check the wires at the starter also.
Old Apr 15, 2014 | 01:56 AM
george536's Avatar
george536
Is it an 05?
http://forums.corvetteforum.com/c6-c...ssues-fix.html
When it doesnt want to start do you hear the column unlock? or is it just quiet and the gauges sweep but no starting?
Old Apr 15, 2014 | 03:18 PM
C6Goyo's Avatar
C6Goyo
Originally Posted by george536
Is it an 05?
It is an 05, im gonna be buying this and hope it fixes the issue. Thanks to everyone for the help!!!
To New intake installed, car won't start
