Cam & Ported intake?
Old Apr 17, 2014 | 07:58 AM
LD85's Avatar
LD85
Default Cam & Ported intake?
OK, I have enough cash right now for either one of the lines below, but not both right now, I can add the remaining items in the winter.
Which would you do now? I am leaning toward the cam and intake package with a tune
1. GT12 or similar Cam & Springs install with a new ported intake & TB
or
2. LT Headers with a newly ported Intake & TB
Old Apr 17, 2014 | 08:53 AM
Big ol 68's Avatar
Big ol 68
Did you factor in the price for a tune? Also with a cam swap gotta factor in the little things. Gaskets, coolant, oil, random sensor you break on accident.
Is it you're daily driver or fun car? Personally I'd go for option 2. Get your car ready for a cam swap. But it's your car, do what will make you happier.
Old Apr 17, 2014 | 09:16 AM
LD85's Avatar
LD85
Mike Norris Motorsports will the the cam install & tune, price includes gaskets, fluids and tune
Old Apr 17, 2014 | 09:26 AM
tennblkc6's Avatar
tennblkc6
i would do lt headers, fast intake and ported tb with a tune then do the cam install at a later date.
Old Apr 17, 2014 | 10:44 AM
LD85's Avatar
LD85
Cam info
Camshaft Swap Installed Package $2195
Includes all of the following:
Choice of any 54-000-11 series Comp Cam either shelf or custom ground.
.650" Lift Dual valve spring kit.
Comp 7.400” moly pushrods.
160* Thermostat.
GM timing cover gasket.
GM timing cover seal.
GM water pump gaskets (2).
GM crank bolt.
Complete Installation and Full Chassis Dyno & Road Tune
Old Apr 17, 2014 | 11:28 AM
Big ol 68's Avatar
Big ol 68
You won't get max performance out of the cam swap unless you have the supporting mods. Do the PnP first then cam. You'll be happier.
It sounds like you've already chose cam swap in your head though. Do what will make you happy.
Old Apr 17, 2014 | 11:37 AM
LD85's Avatar
LD85
I know it won't be complete until the intake and cam can flow enough thru the exhaust, in reality, it should all be done at the same time, I know that.
I will do the intake and TB next weekend then decide on the next step
Old Apr 17, 2014 | 01:33 PM
irok's Avatar
irok
Default ported Fast 102?
do the ported Fast and OBX catted LT headers. $1,800. to $2,000. if you can do the install yourself. if anyone touches your tb nail him between the eyes with a ball peen hammer.this will work without a tune but should be checked on dyno for Air Fuel Ratio before beating on it.
Old Apr 17, 2014 | 02:37 PM
LD85's Avatar
LD85
Yep, I'll do the install
To Cam & Ported intake?
