Obd ii problem
Old Apr 20, 2014 | 02:11 PM
REODAWG's Avatar
REODAWG
Default Obd ii problem
No engine light on just had scan cleared replaced maf sensor and went to have sticker know when they hook up the emission for the sticker they keep getting a not connected error so did not pass -and lighter works so its not the fuse anybody know what I should do
Old Apr 20, 2014 | 05:20 PM
Dano523's Avatar
Dano523
Lighter is constant hot.
The car has to be in ACC mode or Run mode (push and hold the bottom of the starter button down for 10 seconds, like you would to put the car into acc with a single quick button push instead) for the scanner to read.
Old Apr 20, 2014 | 06:43 PM
haljensen's Avatar
haljensen
If you just cleared a CEL you probably have to have a few "Drive Cycles" before the Machine shows the code cleared.
Old Apr 21, 2014 | 11:07 AM
REODAWG's Avatar
REODAWG
but the car has to be running for emissions -its not picking up the scan tool it keeps saying not connected
Old Apr 21, 2014 | 11:08 AM
REODAWG's Avatar
REODAWG
so if you clear the CEL that makes it so the scanner tool wont even connect to the car-because mine just says not connected
Old Apr 21, 2014 | 03:04 PM
tennblkc6's Avatar
tennblkc6
i believe it states something like "system not ready"...
from further reasearch it's probably going to be a blown fuse causing your issue. or the tool is not making a good connectionbetween the male and female plugs.
Old Apr 21, 2014 | 04:04 PM
VET4LES's Avatar
VET4LES
Any time you clear a code the C6 has to be driven for a few days or so before a smog test can be done. If that was not true we could clear a code in their parking lot before the test and the light could come right back after the test.
Old Apr 21, 2014 | 06:39 PM
haljensen's Avatar
haljensen
No, not true. Don't confuse clearing a CEL with connecting the OBD2 reader.
Not connected means just that-----NOT CONNECTED. It has nothing to do with CEL's being present or not.
Read the other posts, the ignition must be on to get a connection between the OBD2 scanner and the car.
To Obd ii problem
