Charging question guys I need help!
Old Apr 22, 2014 | 08:28 PM
shawnaj7731's Avatar
shawnaj7731
Default Charging question guys I need help!
Hey guys I recently had my H/C/I and long tube headers and UD pulley 10%. I am getting a intermitted service charging system message on the DIC, I see my voltage at times will be at around 13.8 then drop down to 12.0 so when it dropped down to the 12.0, I checked the terminal on the back of the alt and it confirms its at 12.0 -11.99 area then it will jump back up to 13.8 and clear. Is the effect from the under drive pulley. If so can the alternator pulley be changed out or is the alternator going bad. Battery test 12.5 with car off.
Old Apr 22, 2014 | 08:37 PM
timd38's Avatar
timd38
Underdrive pulley will cause that to happen. I had the same problem. Replaced it with Billet Tech alternator and never had another issue. My stock alternator was fine, it just wasn't made to run at lower RPMs and still put out the required power.
http://forums.corvetteforum.com/c6-f...ternators.html
Old Apr 22, 2014 | 08:57 PM
shawnaj7731
see I am confused I hear others say they did 25% ud pulley and have no issues.
Old Apr 22, 2014 | 09:03 PM
DSOMC6's Avatar
DSOMC6
Increase your idle RPM.
Old Apr 22, 2014 | 09:08 PM
timd38's Avatar
timd38
Depends on how you define issues. The low voltage at idle didn't bother me, I liked the way the alternator looked and 13.8v at idle was a side benefit.
Old Apr 22, 2014 | 09:28 PM
VET4LES's Avatar
VET4LES
It does look
Old Apr 22, 2014 | 09:41 PM
tennblkc6's Avatar
tennblkc6
Originally Posted by VET4LES
It does look
I concur..purty
op...you could try an overdrive alt pulley.
To Charging question guys I need help!
