Acceleration / Daily driving problem, PLS HELP !!!
Old Apr 30, 2014 | 05:53 AM
Alex_Mx's Avatar
Alex_Mx
Default Acceleration / Daily driving problem, PLS HELP !!!
Hi everybody, i have a really annoying problem with my 2007 corvette C6 LS2, some time from now, the problem was minor, but now with time, it got worst and worst , now, i can´t drive my vette.
While driving, if i hit a little hole or a small bump or whatever it makes the car vibrate under the car, most of the times the RPM gauges and the mph gauges go up and down really fast and then the gauges go back to normal,(i can hear the car accelerates by itself ) AND AT THE SAME TIME THE CAR SHAKES LIKE IF ONE GEAR GOES DOWN, meaning , if i´m driving ( my vette has an automatic transmission ) and i´m in 3rd gear, while driving, go thru a little hole or something that will make the car shake or vibrate relatively hard, it will make this both malfunctions AT THE SAME TIME, gauges go crazy for a few seconds and the car will shake / feel like there´s something wrong with it and then go back to normal.( LIKE GOING DOWN 1 GEAR BUT AGGRESSIVELY / HARD )
I alrdy took my car with 2 of the best mechanics near my city, and so far nothing, i drove my vette yestarday , supposedly we found what it was, we found some wire under the co-driver carpet where you put your feet, there is a fuse box there, and the wire was a little bit trampled and out of place, we put that wire back in place and protect it with some dealer sponge to avoid future problems, after we fixed that, took a drive and NOP, still had the problem.
My mechanic has the dealer computer / scanner and there are no codes of anything, the only one he got was the U1000 AND P0300, the u1000 is miscommunication from modules 2 and 4 , or serie 2 and 4 something like that.
We checked the fuse box from the engine, wire from the transmission (under the car ), oil from the engine level its ok and transmision oil, both are brand new just a few weeks ago, brand new thermostat, brand new air filters, coolant ok, and some other things brand new installed just for maintainance .
The next step is to check the spark plugs and the wire, but i don´t think the problem will be there, i believe there is an electric problem, and i haven´t found it yet ...
I would really appreciate any help i can get from anyone to solve my problem .. i just can´t drive the car anymore and it makes me feel really sad ... Any questions about this issue please feel free to ask .
Alex
Old May 2, 2014 | 12:46 AM
Alex_Mx's Avatar
Alex_Mx
This is my engine
Old May 4, 2014 | 06:51 PM
cclive's Avatar
cclive
If it were me, the first thing I would check would be the two big blue connectors going into the BCM under the passenger footwell carpet. It seems fairly likely that it is some loose electrical connection that is being bumped around. Unfortunately there are many of these connections in the car.
Old May 5, 2014 | 03:09 AM
Alex_Mx's Avatar
Alex_Mx
indeed, we are focusing specifically in that area, we are moving some wire from there, i have a friend who has a 2006 z06 and he let me use his car to make comparisons, we switched the module underneath the co-driver carpet, there´s a fuse box there, from the z06 to my C6 to see if it was the module, and it seems that´s not the problem, when we put the module from the z06 to my c6 i took a drive and the malfunction still was there but minor .. so that´s what we are doing right now, i have both cars together checking from one to another and see if we can find the problem ..
If anyone can help with this please feel free to advice!!
i´ll keep you guys posted if anything new comes up ..
Thanks again
Old May 5, 2014 | 03:36 AM
Alex_Mx's Avatar
Alex_Mx
Here are some photos :
Old May 7, 2014 | 11:30 PM
Alex_Mx's Avatar
Alex_Mx
Problem solved , after 10 days of hard work, the problem was in the module stored under the carpet from the co-driver seat, after some testing, the connectors were loose, after tighten the connectors it seems the car is back to normal , thanks to all the people who tried to help me thru all this process , Finally i can drive my car again !! i´m so happy !!
Alex
Old May 8, 2014 | 07:12 AM
tennblkc6's Avatar
tennblkc6
glad you got it sorted...and thanks for sharing the outcome.
Old May 8, 2014 | 10:13 PM
Alex_Mx's Avatar
Alex_Mx
Some pictures:
To Acceleration / Daily driving problem, PLS HELP !!!
