Of course the Callaway didn't drone, the baffles don't open until 3500 RPM.
You'll always have drone with the baffles open at low RPM regardless of what else you do with the rest of the exhaust, open exhaust at low RPM under load = drone.
If you want to run with open exhaust and eliminate the drone, here ya go http://www.planet-9.com/987-cayman-b...struction.html
It might be a little cramped to do this properly but even an attempt is going to get rid of a lot. Its a lot of work when you can just close the exhaust valve
That is quite an answer by ra! But one would have to plug in whatever is the resonance range for the C6, do the math and then figure out how it will all go together. That's a lot of work but may be worth it if the space is there.
