dead miss no codes
I started my twin turbo LS2408 build in February and am almost done after a circus of shenanigans. Anyway, I FINALLY got to start the car up last night and I have a dead mis on the passenger side. Obviously the car runs rough and will eventually die and have hard starts afterwards from it loading up with fuel.
I checked:
1) Spark- Nice clean and bright spark on all cylinders
2) Fuel signal- although I haven't pulled the injectors to check if the were spraying. I did check the signals on all cylinders with a test kit and the signals checked out. (Keep in mind these are brand new ID1000's so I don't expect one to be bad.
3) Codes- no codes pending or stored.
I will check compression when I get back from traveling next week but does anyone else have any suggestions? The engine ran strong before starting the twin kit so I don't suspect an issue with compression. I changed so many parts in the last few months and haven't started it so i guess the possibilities are endless. Hopefully you guys have some insight on where I can start looking next.
Do you have a baseline tune for the new set-up?
Are the O2 sensors installed in the correct spots?
Are there any wires melted and shorting?
Have you made any changes to the engine?
On the back two (cylinders 6&8) the header is cold/warm and not hot like the others after running for a couple of minutes. Those cylinders do have fuel and spark.
The O2's are in the factory location. I have factory manifolds with the turbo Kit. The O2's seem to be working and are only a couple of months old (new from GM)
It is a brand new harness. I double checked nothing was pinched and made sure my ground cables we tight and touching bare metal.
Yes, I made a lot of changes to the engine and they are as follows:
New lifters (crane)
New pushrods
Cometic thick headgaskets to lower compression
New TT spec cam from Vengeance
New timing chain
Meiling oil pump
New Engine harness
ID1000's
