2007 What LS engine
Old May 10, 2014 | 06:46 AM
The Bus's Avatar
The Bus
Default 2007 What LS engine
I just bought a 2007 corvette, not a ZO6. What LS series engine/HP is it??
I'll be tracking and AutoXing it with Hoosier A6s. On track is there going to be issues with oil pressure [ need accusump ??] or over heating.
Old May 10, 2014 | 07:26 AM
tennblkc6's Avatar
tennblkc6
ls2
Old May 10, 2014 | 08:52 AM
timd38's Avatar
timd38
Just drive it.
Old May 10, 2014 | 11:09 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
LS2, 400 HP, have fun!
Old May 10, 2014 | 12:11 PM
bobeast's Avatar
bobeast
You didn't see that big LS2 stamped on the plenum cover when you opened the hood?
Old May 10, 2014 | 12:35 PM
dennis50nj's Avatar
dennis50nj
add extra quart of oil
Old May 10, 2014 | 01:47 PM
The Bus's Avatar
The Bus
I have not seen under the hood. A friend never drove it much and I bought it.
Old May 10, 2014 | 02:05 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
Guess it time to start reading the owners manual. I think it was the first owners manual I ever read, lot of interesting stuff in there I never new.
Old May 13, 2014 | 09:08 AM
el es tu's Avatar
el es tu
AutoX is so short, overheating wouldnt be an issue. If youre going to the track or doing extended backroad runs, the summer heat can build up quickly.
Oil pressure issues occur on longer left hand turns so the factory suggests adding an extra qt for hard use. If you ever decide to add a drysump, look into Aviaid. They have several kits with an entry level one starting at around $1800.
Have fun!
To 2007 What LS engine
