Mini Starter for 2005?
Old May 10, 2014 | 08:08 PM
LD85's Avatar
LD85
Default Mini Starter for 2005?
I will install my headers this coming week, and I know that on my 1985, the Mini Starter afforded more clearance around the header area, so.....
is there a need for more clearance and do they make a mini starter?
Old May 10, 2014 | 08:53 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I haven't read of one, but maybe someone in the roadracing section has. Or one of the tuner/vendors such as ECS or DRM. I'd check with them.
Old May 10, 2014 | 08:56 PM
saplumr's Avatar
saplumr
Headers are installed by the thousands without a starter clearance problem.
Old May 10, 2014 | 09:00 PM
LD85's Avatar
LD85
Heat Soak, not clearance, I have a DEI start insulation, so if that is sufficient, then even beter
Old May 10, 2014 | 09:26 PM
saplumr's Avatar
saplumr
With my blower on 100+* days I can run 220-230+ temps and I've never had any issue.
Old May 11, 2014 | 06:35 AM
LD85's Avatar
LD85
Works for me then, $300 saved
The 85 would heat soak after long drives, not fun
Old May 11, 2014 | 11:46 AM
jerho's Avatar
jerho
If you are taking about a high torque starter. I would be very cautious most will not clear headers. Is very hard to know before buying.
Old May 11, 2014 | 07:47 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
All LS motors have a traditional 'mini' starter
Old May 12, 2014 | 10:35 AM
LD85's Avatar
LD85
Thats good to know, I put the car on the ramps last night to look around, it does look much smaller than my 85's starter, so I will wrap it with a heat blanket and see how it goes.
I'm knew to the LS engines but we'll figure it out little by little.
To Mini Starter for 2005?
