07 c6 ls2 WOT issue on freeway!
Old May 16, 2014 | 01:38 PM
Burken01's Avatar
Burken01
Default 07 c6 ls2 WOT issue on freeway!
Ok guys I have a few questions, I was driving on the freeway yesterday in 102 degree weather for an hour or so
Water temp, oil temp, trans temp are all Fine and in normal range
Water temp - 210
Oil temp - 210-220
Trans temp - 190ish
So I'm coming up on my off ramp and already going about 60-70 mph and I punch it WOT and the car falls flat and doesn't accelerate at all but I can hear the engine revving.. Almost felt like I was In neutral for a sec...
I come to a complete stop at the light and go WOT again and it was fine.. Pulled great from 0-60 before slowing down again
So what gives?
I was in "s" mode no paddle shifting
Old May 16, 2014 | 02:14 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I've heard a couple of other people experience a similar issue, but never found out if it recurred or if they got something fixed.
Occasionally, you get lucky and it turns out to be a one-time glitch that never returns.
Occasionally...
Old May 16, 2014 | 02:25 PM
Burken01's Avatar
Burken01
Yea at first I thought it was a glitch in the throttle body since its electric vs cable in fbody cars..
Idk no engine light came on
Old May 16, 2014 | 03:21 PM
EVRose's Avatar
EVRose
Not to change the subject but were you in traffic on the freeway or at cruising speed? 210º coolant temp seems high unless you were in a lot of traffic.
Old May 16, 2014 | 03:48 PM
Burken01's Avatar
Burken01
Traffic, maybe heat soak caused the car to just fall flat?
Old May 16, 2014 | 04:01 PM
shawnaj7731's Avatar
shawnaj7731
the coolant temp is normal. Specially if he does not have at 160T stat.
Old May 16, 2014 | 04:15 PM
Burken01's Avatar
Burken01
So adding the 160 stat will be a better upgrade?
Old May 16, 2014 | 04:46 PM
shawnaj7731
yes if you have the fans tuned to work with the t stat
Old May 16, 2014 | 04:49 PM
EVRose's Avatar
EVRose
Normal in traffic, yes. On the freeway mine is constant 196-198º and I have OEM T-stat. Having said that I don't think the temp had anything to do with the car not accelerating. I don't know what the cause of that would be.
Old May 16, 2014 | 05:59 PM
Burken01's Avatar
Burken01
Mine was 200ish while driving and 210 or so in traffic..
To 07 c6 ls2 WOT issue on freeway!
