Strip tips?
Old May 16, 2014 | 09:27 PM
Whisky's Avatar
Whisky
Default Strip tips?
Hi everyone,
I have an '08 Z51 coupe, manual trans, headers, borlas and stock run flats.
I've done plenty of drag racing with previous cars but this will be my first time with my Vette. I'm sure I'll have to play the launch by ear but any tips on shift points(rpms?), tire pressure or anything else that would be of help. Should I try to power shift with stock tires? Also, what setting on the nannies is best? Traction control off but the rest on?
My Vette club is going to the local 1/8 mile strip in a couple of weeks.
Thanks in advance!
Marc
Old May 16, 2014 | 10:46 PM
HOXXOH's Avatar
HOXXOH
Originally Posted by Whisky
Hi everyone,
Thanks in advance!
Marc
If your runflats are the originals from day one, you'll have real problems trying to hook that hard rubber even with the 25-26 psi that most people run. Newer tires will stick better. I wouldn't try power shifting, since just a little bit out of line will kick in the nannies. TC off and be sure to immediately abort the pass if you get wheel hop.
Most importantly, don't stress out, just have fun.
Old May 17, 2014 | 01:52 AM
C7/Z06 Man's Avatar
C7/Z06 Man
Wheel hop can break your rear.
Old May 19, 2014 | 03:05 PM
JaimeVrod's Avatar
JaimeVrod
I got my best passes with rear tire pressure at 24 psig, speed shift the 1-2 shift and power shift the 2-3 shift. Look for a thread with input by Ranger on drag strip technique. His write up is awesome. I this his experience was with a C5 but nevertheless practically everything is still applicable.
Old May 19, 2014 | 03:06 PM
JaimeVrod's Avatar
JaimeVrod
By the way, those passes were on Eagle F1 run flats which are horrible at the drag strip.
Old May 19, 2014 | 06:40 PM
4SUMERZ's Avatar
4SUMERZ
Strip tips?
Preferably to music with a strip pole
oops! sorry, wrong forum
To Strip tips?
