Tail Light Bulbs
Old May 18, 2014 | 10:11 PM
Tonylmiller's Avatar
Tonylmiller
Default Tail Light Bulbs
One of my tail light bulbs has stopped working (the turn signal only).
Are these bulbs hard to find? They seem to be expensive. Anyone had good luck find them at Wal-Mart or where else?
I see that I can order them online but I will pick one up locally if I can.
What about similar part numbers like 3057LL?
Old May 18, 2014 | 10:45 PM
Tonylmiller
I found a decent price on ebay, less than $4 shipped. That's the best I could find.
Old May 19, 2014 | 06:25 AM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
any parts store should have the bulb, very common
one torx screw and the light assembly comes out
Old May 19, 2014 | 09:24 AM
kimdjay's Avatar
kimdjay
You say the turn signal only, it does NOT come on for braking too correct. If it is absolutely only the turn signal, you have another problem. and yes the normal replacement bulb is a very common 3157.
If you happen to be changing more than one bulb at a time, make sure to note that there are right hand tail lights and Left hand ones. I didn't both to think about that once and ended up with a strange looking set of lights as they come on.
Old May 19, 2014 | 09:48 AM
Boomer111's Avatar
Boomer111
Are you serious?
Old May 19, 2014 | 09:55 AM
Tonylmiller
I haven't checked it for braking. I will verify when I get home. Rode the bike to work today.
Old May 19, 2014 | 02:26 PM
j_digi454's Avatar
j_digi454
Originally Posted by Boomer111
Are you serious?
I think he meant the bulb housings, not the bulbs.
Old May 19, 2014 | 06:14 PM
cclive's Avatar
cclive
Yes, the housings are left and right and are marked as such. The bulbs have two filaments, so you could have parking light working and brake/blinker not, but brake and blinker must be the same if the bulb is the cause. Also, when you replace the taillight housing into the car, be careful not to push the speed nut off and down behind the fascia...it will be hard to find.
Old May 19, 2014 | 08:10 PM
Tonylmiller
Thanks for the heads up.
Old May 19, 2014 | 08:38 PM
Boomer111's Avatar
Boomer111
Thanks for the clarification.
Old May 19, 2014 | 10:38 PM
Tonylmiller
It is the bulb. The brake light doesn't work on that assembly, either.
To Tail Light Bulbs
