Replacing muffler
Old May 20, 2014 | 08:22 PM
The Trock's Avatar
The Trock
Default Replacing muffler
Does anyone have the instructions on replacing a 2006 z06 NPP muffler drivers side only?
Old May 20, 2014 | 09:24 PM
96GS#007's Avatar
96GS#007
- Raise car and support appropriately
- unbolt sway bar from the cradle (NOT the end links)
- disconnect vacuum line going to the actuator
- loosen muffler clamp
- remove the bolts that hold the muffler hangers in place
- Rotate muffler while guiding the pipe around/over the transmission
- remove muffler hangers from the muffler and move to the new one (or leave in place if re-using)
Very easy on a lift. Most say you need at least 18" of height if you're doing it on jackstands.
Old May 21, 2014 | 09:34 AM
haljensen's Avatar
haljensen
If you remove the mid pipe before trying to remove the muffler(s) the work will be MUCH easier.
Old May 21, 2014 | 04:55 PM
The Trock's Avatar
The Trock
Thanks The Trock
Old May 21, 2014 | 04:56 PM
The Trock's Avatar
The Trock
Thanks and good idea!!
The Trock
To Replacing muffler
