Small Oil Leak
Old May 20, 2014 | 10:30 PM
dcking04vette's Avatar
dcking04vette
Default Small Oil Leak
Guys,
I've got a 2006 and I barely drive it with 40K miles on the speedo. I noticed the other day that there was a small oil leak under the car when I moved it out to work in the garage. I know there is a lot of things that it could be, but could this be part of the whole catch can need that I hear of for the LS2? Thanks in advance.
Old May 20, 2014 | 10:37 PM
RicK T's Avatar
RicK T
Could be a lot of things. These cars really don't leak much. A common issue is the oil pan gasket. Can you get under it and check for obvious things?
Here are a couple representative threads to review:
http://forums.corvetteforum.com/c6-t...cs-inside.html
http://forums.corvetteforum.com/c6-c...y-oil-pan.html
Old May 20, 2014 | 10:39 PM
dcking04vette
Well, looking at the other posts, it doesn't appear to have anything to do with the catch can, but more oil pan gasket. I will pull on ramps and look around, but I would love to hear what others have found. It's just a small amount. Telling me what each of you have found out, so I could know where to look.
Old May 20, 2014 | 10:43 PM
dcking04vette
Will do. Thanks
Old May 21, 2014 | 06:31 PM
Red08's Avatar
Red08
The same thing happened with mine. One day I noticed a couple of drops, and got under the car. I could see a drop or two on the rear bolt heads, and what appeared to be a light film along the side of the pan. I cleaned everything up, and didn't notice it again for a 2-3 weeks, so it was REAL slow. Anyway, it turned out to be a leaking oil pan gasket. I got it replaced about a month ago, and it has been fine since. The oil leak wasn't much, but I just didn't like the thought of knowing it leaked, however slow it was.
To Small Oil Leak
