For the last few years I've had a hard start problem I blamed on batteries. Last year I found my fuel relay was darkened by overheating so I replaced it. Car seemed fine but intermittently now the car can lose total fuel pressure as if the relay kicks out. I've switched relays around and nothing but after sitting a few minutes you can hear the relay kick back in and presurre's back up. I've checked the fuse terminal block and definitely have a burned post for the AC compressor but the fuel pump terminals look fine. Searching for any suggestions.
