Yep thats your active handling system kicking in.
If you're wheel is not centered,there's a sensor for steering angles under the dash. Your car thinks its in a adverse yaw condition and is trying to straighten the car out.
Also check your TPMS. If you ever hit the track and the TPS aren't registered to the car you'll get a similar experience. Ask me how I know.
So is that the fix, have the alignment done? Thanks
GM issued a TSB to install a retaining clip on the Steering Wheel Position Sensor connector in the steering column. If your car has not had that done, getting it done "may" solve the problem for you, but it isn't guaranteed.
From your description you could have an issue with the AH. However, if the steering wheel is cocked a lot to one side that will usually cause the system to shut down. Once the system sees a signal showing the wheel turned a constant amount without the yaw and g sensors reporting a turn it shuts itself down. Did you see a Service Active Handling message? Also get a scanner that can read ABS codes and see if there are any ABS codes.
The recall had to do with a problem with the steering sensor connector and fretting of the connector pins. That would generate spurious signals that could cause the AH to react.
The symptoms you mention could also be related to an issue with a tie rod, wheel alignment, wheel balance, or a loose wheel hub.
