I will install the RSD shifter box Saturday, and I am wanting to know if;
1. is it advisable to add Dynamat in hte shifter box area?
2. If yes, how much do I need, can you slip some under the carpet on the side tunnel as well as inside the shifter area?
1. Yes
2. You can put it anywhere except where it obstructs mechanical motion.
I used the amount that MGW provided with my shifter. There are MGW shifter installation videos on YouTube that you can follow to install your RSD shifter (kinda funny), well at least that show how/where to install the Dynamat.
