tailight bulb replacement 05 c6
Old May 29, 2014 | 05:08 PM
Louis005's Avatar
Louis005
4th Gear
Default tailight bulb replacement 05 c6
I recently bought an 05 c6 vette and one tailight went out. I got manual when car purchased. My question is how do get to the bulb to replace it?
Old May 29, 2014 | 05:30 PM
tennblkc6's Avatar
tennblkc6
there's a small screw at the top of the lens...you need to remove it and the light assy will come out then you will see how to remove the bulb.
Old May 29, 2014 | 10:57 PM
Louis005's Avatar
Louis005
4th Gear
Thank you for the help.
Old May 30, 2014 | 01:53 PM
cclive's Avatar
cclive
Be very careful after you replace the bulb and go to put the whole assembly back in the car. It is easy to push the top against the speednut that the screw goes into. It will slide off the back and fall down behind the fascia, never to be seen again.
To tailight bulb replacement 05 c6
