rps clutch ???
Old May 31, 2014 | 05:24 PM
hnaskoct's Avatar
hnaskoct
Default rps clutch ???
I wanna know does the rps twin disk clutch use an aftermarket throw out bearing or a wider bearing... I'm under a friends car and it has busted the 2nd slave cylinder ..and when I put the bearing against the claws on the pressure plate there's there isn't hat much room for it to always hit flush ..seems like if the bearing was wider then it would be fine
Old May 31, 2014 | 05:43 PM
Turbo2L's Avatar
Turbo2L
Call Rob or RJ at RPS. They are a wealth of knowledge are more than willing to help you troubleshoot.
Old May 31, 2014 | 06:38 PM
hnaskoct's Avatar
hnaskoct
I've been doing research..looks like there's a bearing adapter that goes in this thing...and its not in there..and ll part or buying a used car THIS Slave Failure HAPPENED the day Right After purchase
Old Jun 1, 2014 | 12:53 PM
GARY2004Z06's Avatar
GARY2004Z06
It comes with an RPS TOB for a C6 when purchased new.
http://www.turboclutch.com/Pages/RPS%20ST%20Half.htm
To rps clutch ???
