Zo6 lifter failure
Old Jun 4, 2014 | 09:46 AM
WICKED Z's Avatar
WICKED Z
Default Zo6 lifter failure
I've got a 2007 zo6 . I've read alot of posts about lifter failure. I have one lifter that failed. Cam looks ok. But all the bearing are out of the roller. What would you do . ( yes i am replacing all 16 lifters) would the bearigs fall staight to the pan ?
Old Jun 4, 2014 | 10:34 AM
DannyBlake10's Avatar
DannyBlake10
are they factory lifters that have been run for a while? or are they new lifters that failed
Old Jun 4, 2014 | 10:47 AM
WICKED Z's Avatar
WICKED Z
Default Lifters
Originally Posted by dannyblake10
are they factory lifters that have been run for a while? Or are they new lifters that failed
factory / 50k miles
Old Jun 4, 2014 | 11:05 AM
Unreal's Avatar
Unreal
Lifter or rocker? Bearings don't typically fall out of the lifter.
If a lifter did fail, I would replace the cam. There is probably cam damage. If it is just a rocker then just replace them with new ones and move on.
Old Jun 4, 2014 | 11:06 AM
DannyBlake10
and the bearings fell out? wow ive never seen that
was the rocker tight? maybe it was loose and this caused a bit of hammering on the lifter
is the wheel still there?
if i were you id just do whatever you need to get all the parts out and put in a new one (or set if you desire)
Old Jun 4, 2014 | 11:13 AM
WICKED Z's Avatar
WICKED Z
and the bearings fell out? Wow ive never seen that
was the rocker tight? Maybe it was loose and this caused a bit of hammering on the lifter
If i were you id just do whatever you need to get all the parts out and put in a new one (or set if you desire)
lifter , roller broke, bearings came out. Trying to see if cam is damaged
Old Jun 4, 2014 | 11:24 AM
DannyBlake10
yea just check that cam and get out any debris and check what comes out. and make sure it all came from the lifter and nothing else
just see this as an opportunity for 'the cam youve always wanted' haha
Old Jun 4, 2014 | 11:27 AM
Unreal's Avatar
Unreal
If the roller broke then then the cam is damaged.
Fairly common in all LS. Trucks have it happen, my motor at 18k miles had a lifter break. Friends car just had one break 2 weeks ago.
Old Jun 4, 2014 | 12:02 PM
Misael's Avatar
Misael
Sorry for the slight hijack but how do you typically know when there is a lifter/rocker failure? Is there a oh **** moment aka car shuts down, ticking noise, bad performance? I'm new to the LS and even newer to my c6.
Old Jun 4, 2014 | 12:51 PM
DannyBlake10
you'll feel a vibration like a misfire would give. most notably at an idle. depending on where the parts that broke apart and fell into the engine could give you many different types of issues, some worse than others.
Old Jun 5, 2014 | 08:15 AM
WICKED Z's Avatar
WICKED Z
you'll feel a vibration like a misfire would give. Most notably at an idle. Depending on where the parts that broke apart and fell into the engine could give you many different types of issues, some worse than others.
well i do need a cam. Can i change the cam without pulling (dropping ) the motor out?
Old Jun 5, 2014 | 12:40 PM
DannyBlake10
yea you just have to remove everything up front. there should be enough room though
Old Jun 5, 2014 | 01:09 PM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
Now you can say you've seen it.
OP you're going to be replacing the cam and all lifters, & flushing the oil system thoroughly.
DO NOT try to force that lifter up through the hole if it doesn't slide right out. Just pull the cam and let lifter drop out the bottom.
More damage has been done to lifter bores from people trying to get them out the top
Old Jun 6, 2014 | 02:13 PM
WICKED Z's Avatar
WICKED Z
Originally Posted by azmotorhead
now you can say you've seen it.
Op you're going to be replacing the cam and all lifters, & flushing the oil system thoroughly.
Do not try to force that lifter up through the hole if it doesn't slide right out. Just pull the cam and let lifter drop out the bottom.
my lifter is just like yours. ( unfortunatly) . I assume you have already changed the cam . . As i ask , if i pull the rad, condenser, and drop the steering rack . Then i can get the came out the front of the motor without pulling , dropping the motor out ? Thanks for any help
Old Jun 7, 2014 | 09:20 PM
AzMotorhead
On my Z the dealer did it under warranty. Heads were pulled,entire rack was removed,as well as coolers and radiator.
So yes if you do all that you can get the cam out.
I'm doing a motor for a fellow club member and we dropped the motor out and are going thru the whole thing.
To Zo6 lifter failure
