Window No Longer Goes Down
Old Jun 4, 2014 | 08:44 PM
dcrafton1's Avatar
dcrafton1
Default Window No Longer Goes Down
My 2006 coupe was hit by a deer about a year and a half ago and the door was found to be cracked and had to be replaced. Shortly after the repairs were completed, the window would "thunk" with about 4" left to go upon descent, but would complete its downward journey. It just recently started stopping at this point and will no longer go all the way down. Other than the last 4 inches, the window works perfectly. It indexes properly (indexing has been reset several times) and goes up and down fine. It's just those last few inches. Since I had to take the car back once due to a noise (a "rattle" of sorts, when closing the door), which was found to be parts not securely fastened, I suspect some other repair anomaly, as opposed to some purely random failure. The window acts as if something is blocking the downward travel. Does anyone have any insight into this, and the innards of the driver door? Is there a wiring harness or something else that could be blocking the final 4" of downward travel? Could this possibly be the regulator?
Sorry for the long post and thanks for reading this far!
Old Jun 4, 2014 | 09:18 PM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
Sounds as though a wiring harness to the door controls has come loose. Ask is anyone has a scanner and can scan the door from the service manual. I dont have a working scanner or I would do it.
Can anyone help them out here???
Old Jun 4, 2014 | 09:26 PM
RicK T's Avatar
RicK T
It is an issue that surfaces pretty often. Need to take the door panel off and get in there and zip tie the harness away from the mechanism. It isn't easy to see or work in there, just be patient and look around 'till you understand it.
It is also possible the regulator wires are fraying and getting caught in the mechanism, which requires a new regulator assembly or repairing the one you have. But that is less likely than the harness scenario.
Old Jun 4, 2014 | 10:04 PM
dcrafton1's Avatar
dcrafton1
Thanks for the replies! I should have an opportunity to gain more knowledge on this subject on Monday.
Old Jun 17, 2014 | 11:20 AM
dcrafton1's Avatar
dcrafton1
Default Solved!
Just for thread completion and to help complete our resources here...
The mirror harness was on the wrong side of the glass! I guess when they hung the new door, and moved my internal parts over, this harness was not properly located.
It's as good as new - again!
Old Jun 17, 2014 | 03:05 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Great to hear
To Window No Longer Goes Down
